Help setting up spotting
Posted: Sat 22. Jul 2017, 22:59
by k3cka
Wondering if someone could point me to a tutorial on how to setup up so I can see dx spots without having to keep a webpage open to dxsummit all the time? I've tried to figure it out, but have not been successful. I'm 100% sure its all user error.
Re: Help setting up spotting
Posted: Sat 22. Jul 2017, 23:17
Posted: Sun 23. Jul 2017, 00:11
by k3cka
I had found that and didn't see where I messed up.
I'm getting no input on my spot window, and terminal comes up with:
Attempt to connect to host timed out
*** Disconnected from dxsummit ***
Like I said, I'm sure its user error but I don't know where.
I have never setup this type of stuff before.
Posted: Sun 23. Jul 2017, 02:07
you should show us your settings in the Preferences below the DX-Cluster tab. It seems to be a wrong cluster address. Do you have tried DB0SUE? This configuration is always in and correct.
Posted: Sun 23. Jul 2017, 13:24
by k3cka
Ok, It seems that I got nc7j and kiel to work, but its not showing much for spots.
What do you enter to get a website like dxsummit to show up in your spot window?
Posted: Sun 23. Jul 2017, 13:38
When there are not much spots in the spot window, but there are spots in the terminal, check your spot filter settings ion the Preferences under the DX-Cluster tab.
RUMlog uses telnet clusters only, no web sites.
Posted: Sun 23. Jul 2017, 13:45
by k3cka
Ok, will do.
I expected more spots to show up. I really appreciate your patience.
I love the log program!
