Page 6 of 12
Posted: Wed 26. Aug 2020, 16:09
by va2cz
Hi !
Is it possible to add the CWops OPEN in the supported contest list if you have the time to add it.
The contest is sept. 5th. Otherwise, no problem.
Thank you
Pierre, VA2CZ
Posted: Sun 17. Jan 2021, 17:48
by theilerj
Hi there,
It would be great if you could add the Swiss SwAC Contest. Here is the link to the website where the rules are also located (German English Italian)
https://www.uska.ch/swac
73 HB9HBV
Posted: Wed 10. Feb 2021, 14:11
by jweisskohl
Can you please add support for the QCWA QSO Party?
Here is the link to the rules:
https://www.qcwa.org/2021-qso-party-rules.pdf
Thank you,
Jerry AC4BT
Posted: Thu 11. Feb 2021, 13:26
by NN7M
Could you add the SST to the list of contests? It’s on two times a week and gaining popularity.
Rules:
http://www.k1usn.com/sst_rules.html
Thank you,
Ryan NN7M
Posted: Sat 4. Sep 2021, 08:55
by RafalLukawiecki
Could you, please, add the UKEICC contests? The next one is at the end of the month. There scoring rules are unique, and the region identifier needs to be exchanged.
Here is the rules page in German:
https://www.ukeicc.com/DXcontestRules/rulesgerman.htm and in English:
https://www.ukeicc.com/dx-contest-rules.php#
Thank you, very much! I hope to make this my first contest using your software.
Posted: Tue 9. Nov 2021, 15:53
by PE2V
I don't know if it is allowed to ask it in this topic,
I want to participate the DAC (Dutch Activity Contest, every Tuesday evening) on VHF / UHF / SHF and there for I need to collect: Call, Report, and LOCATOR. The points is the distance in KM's between the locators. Every unique locator gives 500 extra points.
But I checked a lot of existing contests in RL but could not find a contest that does this
Does anybody know which contest is calculating what I need for the DAC? At least the distance. 500 pnts per unique locator is not necessary.
Thanks for any suggestions!
Vy73 Vincent PE2V
Posted: Tue 9. Nov 2021, 16:07
Check the
RSGB UKAC or the
SSA Kvartalstest contests. Sounds similar to me.
Posted: Tue 9. Nov 2021, 16:16
by PE2V
DL2RUM wrote: ↑Tue 9. Nov 2021, 16:07
Check the
RSGB UKAC or the
Thanks!! Checked but both require a serial number... it should be a contest without serial number..
Vy73 Vincent
Posted: Tue 9. Nov 2021, 16:20
Maybe the
Global Mountain Activity Contest ? It's 2m only.
Posted: Tue 9. Nov 2021, 16:44
by PE2V
DL2RUM wrote: ↑Tue 9. Nov 2021, 16:20
Maybe the
Yessss..... but you're right, for VHF only... UHF is not allowed
