Page 6 of 7
Posted: Thu 16. Feb 2012, 18:44
by ua4fqi
DL2RUM wrote:You can only add a note to the QSO, not very user friendly. It seems i have to more modes. But no spare time yet .....
If you have free time, correct for the following contest.
Thank you for your support.
73!
Posted: Fri 24. Feb 2012, 18:04
by ua4fqi
I very much liked to work in contest on your program. If you have time, ask to add Open UKRAINE RTTY Championship
http://uarl.com.ua/openrtty/2012/rtty2012e.txt
Thankful in advance!
Posted: Fri 24. Feb 2012, 18:12
The idea behind the plugin concept is, the user can create own contest templates. Please try it yourself using the ContestMaker tool. There are a lot of examples provided.
Scandinavian Activity Contest - SAC
Posted: Fri 16. Mar 2012, 18:15
OQRP
Posted: Fri 6. Jul 2012, 18:39
http://www.qrpcc.de/contestrules/oqrpr.html
OQRP.plist
(8.12 KiB) Downloaded 1601 times
OQRP.plist
NRAU-Baltic-Contest
Posted: Sat 8. Dec 2012, 10:55
DL-DX-RTTY Contest
Posted: Fri 5. Jul 2013, 10:02
Posted: Mon 3. Mar 2014, 23:09
by kf5jra
Colorado QSO Party
Since I live in Colorado and I noticed that there is not a file for the Colorado QSO party I thought I would give it a try. It is far from being complete which is why I am posting it here along with the link to the documentation for last years contest. My first stumbling block is the RX strings. For the COQP it is Name and State (2 boxes) The second is the different points for modes and categories.
Here is the link for the rules:
http://ppraa.org/downloads/coqp/2013%20 ... 2013-1.pdf
Thank you in advance.
Re: Colorado QSO Party
Posted: Wed 5. Mar 2014, 01:52
I sent you a p-mail
Posted: Wed 5. Mar 2014, 17:39
by G4FSU
One point I've noticed on RTTY with the K3 is that the K3 internal RTTY decoder is often better than cocoamodem. I find I am reading the received info off the K3 display and not the RX window on RUMped.
Would it be possible to have the K3 internal modem as an option for both TX and RX within RUMped? This is available on RUMlog, but not for contests! PSK31 TX/RX on the internal modem would be good also - especially if PSK63 is added to the K3 which has been discussed on the Elecraft reflector.
Many thanks & 73,
Ian G4FSU
