Page 5 of 12
Posted: Mon 3. Feb 2020, 09:34
I'm sorry, you are right. I looked into the ARRL 160m contest. I will correct that.
73 de Tom, DL2RUM
Posted: Sun 23. Feb 2020, 13:25
by PE2V
Is it possible to change the contest name? I'm talking about this contest:"IARU-Region-1 145 MHz Contest September". In our country we have 4 times a REG1 VHF contest which uses the same rules. So I can use the "IARU-Region-1 145 MHz Contest September" for the REG1VHF contest of March, May, July and September but in the export the name "IARU-Region-1 145 MHz Contest September" is not correct for these other 4 contests. Is it possible to rename or duplicate the contest preset? Or, one preset for REG1VHF would be great.
Thanks and Vy73,
Vincent PE2V
Posted: Sun 23. Feb 2020, 13:40
I'm not very familiar with VHF contests. I guess these are the same as:
  • DARC VHF-, UHF-, Microwave Contest March
  • DARC VHF-, UHF-, Microwave Contest May
  • DARC VHF-, UHF-, Microwave Contest June
  • DARC VHF-, UHF-, Microwave Contest July
Just change the name in the EDI file.
Posted: Sun 23. Feb 2020, 13:52
by PE2V
Thanks, yes, these look the same. I'll give it a try..
Thanks!
Posted: Wed 15. Apr 2020, 16:30
by NN7M
If you have time, please add the New England QSO Party. It takes place the first weekend in May.
http://www.neqp.org/rules.html
https://www.contestcalendar.com/contest ... php?ref=10
Thank you,
Ryan NN7M
Posted: Wed 15. Apr 2020, 16:35
It's already supported.
Posted: Wed 15. Apr 2020, 18:20
by NN7M
I see it now. 😬
Posted: Fri 12. Jun 2020, 00:58
by K7HPN
Here are a couple of weekly contests that could be added to RUMlogNG:
Posted: Fri 26. Jun 2020, 13:42
by sndtubes
Is there any RumLogNG option for Field Day? I was hoping to use RumLog for Field Day. Hate to switch back to N1MM. I know others have asked, but couldn't find much response of late.
Posted: Fri 26. Jun 2020, 15:37
RL supports the
  • IARU Region 1 Fieldday
  • RSGB CW National Field Day
  • RSGB SSB Field Day
  • DARC UKW-Winter-Fieldday
  • DARC UKW-Sommer-Fieldday
  • WFDA Winter Field Day
You should be a little bit more specific.
