List of supported contests
Re: List of supported contests
I'm sorry, you are right. I looked into the ARRL 160m contest. I will correct that.
73 de Tom, DL2RUM
PE2V
Unread post by PE2V »
Is it possible to change the contest name? I'm talking about this contest:"IARU-Region-1 145 MHz Contest September". In our country we have 4 times a REG1 VHF contest which uses the same rules. So I can use the "IARU-Region-1 145 MHz Contest September" for the REG1VHF contest of March, May, July and September but in the export the name "IARU-Region-1 145 MHz Contest September" is not correct for these other 4 contests. Is it possible to rename or duplicate the contest preset? Or, one preset for REG1VHF would be great.
Thanks and Vy73,
Vincent PE2V
I'm not very familiar with VHF contests. I guess these are the same as:
  • DARC VHF-, UHF-, Microwave Contest March
  • DARC VHF-, UHF-, Microwave Contest May
  • DARC VHF-, UHF-, Microwave Contest June
  • DARC VHF-, UHF-, Microwave Contest July
Just change the name in the EDI file.
PE2V
Thanks, yes, these look the same. I'll give it a try..
Thanks!
NN7M
Unread post by NN7M »
If you have time, please add the New England QSO Party. It takes place the first weekend in May.
http://www.neqp.org/rules.html
https://www.contestcalendar.com/contest ... php?ref=10
Thank you,
Ryan NN7M
It's already supported.
NN7M
I see it now. 😬
K7HPN
Unread post by K7HPN »
Here are a couple of weekly contests that could be added to RUMlogNG:
sndtubes
Unread post by sndtubes »
Is there any RumLogNG option for Field Day? I was hoping to use RumLog for Field Day. Hate to switch back to N1MM. I know others have asked, but couldn't find much response of late.
RL supports the
  • IARU Region 1 Fieldday
  • RSGB CW National Field Day
  • RSGB SSB Field Day
  • DARC UKW-Winter-Fieldday
  • DARC UKW-Sommer-Fieldday
  • WFDA Winter Field Day
You should be a little bit more specific.
