Re: Voice Keyer on TS-590S No audio
Posted: Sun 28. Aug 2016, 08:33
Just tested again on a IC-7300, works perfect.
RUMsoft, software for HAM radio on the Mac.
https://dl2rum.de/forum/
Has nothing to do with it.DL2RUM wrote:Do you have tried Data mode?
Yes. But what I notice is that many times the default audio device for the Mac is set to the Codec. Is RumLog doing that?DL2RUM wrote:Volume is up?
Not that I know of. I usually try with no other applications running.DL2RUM wrote:Is any other application using this audio codec?
I think i found it. Whenever i play my audio file using Audio, Recording to File, Use for voice keyer i an only see audio on the left channel. The TS-590 only uses the right channel. So i converted the file to two channels and now things are working.DL2RUM wrote:When you start to playback over the radio, the saved output level will be set.
You can check the RUMlog function: just set the output device for radio to "Internal"
