[Solved] Voice Keyer on TS-590S No audio
Re: Voice Keyer on TS-590S No audio
Just tested again on a IC-7300, works perfect.
EA3HOE
Unread post by EA3HOE »
Crap.... I have no idea where to look next..... :?
Do you have tried Data mode? Volume is up? Is any other application using this audio codec?
EA3HOE
DL2RUM wrote:Do you have tried Data mode?
Has nothing to do with it.
DL2RUM wrote:Volume is up?
Yes. But what I notice is that many times the default audio device for the Mac is set to the Codec. Is RumLog doing that?
DL2RUM wrote:Is any other application using this audio codec?
Not that I know of. I usually try with no other applications running.
Ton.
When you start to playback over the radio, the saved output level will be set.
You can check the RUMlog function: just set the output device for radio to "Internal"
EA3HOE
DL2RUM wrote:When you start to playback over the radio, the saved output level will be set.
I think i found it. Whenever i play my audio file using Audio, Recording to File, Use for voice keyer i an only see audio on the left channel. The TS-590 only uses the right channel. So i converted the file to two channels and now things are working.
Thanks for your support (and patience).
Ton.
