Contest Definition Files, Contest Maker
- N8NOE
- Location: Waterford, MI. USA [30 Miles, N.W. of Detroit]
- Contact:
Re: Contest Definition Files, Contest Maker
Tom;
Wasn't there a BARTG RTTY contest Plugin?. I just looked and didn't see one after noting the contest this weekend?
I keep older Versions but will look there also, Could have swore there was one.
Jeff-N8NOE
Jeff-N8NOE
"Laissez les Contest Roulez!"
Re: BARTG
No Jeff, there wasn't. In this contest you have to send the time as control number. This is not supported by RUMped yet, but you can set it manually prior each QSO - not very practicable. I'm short on time in these days, I guess, it will be ready for the next contest.
- N8NOE
- Contact:
No Problem Tom, I'd Just thought it was there.
Everyone seems busy latley so no problem.
Haven't been feeling real great with the WX here
So I will play and Log try to see what happens.
TARA RTTY Melee
Due to a bug in RUMped (http://dl2rum.de/forum/viewtopic.php?f=3&t=170) use the following corrected plugins for the TARA RTTY Melee contest:
- Attachments
- TARA RTTY Melee NA-side.plist
- (14.27 KiB) Downloaded 1314 times
TARA RTTY Melee NA-side.plist- (14.27 KiB) Downloaded 1314 times
- TARA RTTY Melee Non-NA.plist
- (14.27 KiB) Downloaded 1309 times
TARA RTTY Melee Non-NA.plist- (14.27 KiB) Downloaded 1309 times
- N8NOE
- Contact:
Tom;
Wasn't there a Plugin for the BARTG-RTTY contest?.. I just thought the contest this weekend, I'd let my Snow Leopard Server
feed my MySQL and use it so I was setting up, and I thought BARTG was in the List.. Did I miss it, or was it taken out?..
Jeff-N8NOE
Jeff-N8NOE
- N8NOE
- Contact:
Just READ (Right at the top of the Page)..
I remember Talking about it but don't remember if it got in or out..
ARRL Sweepstakes
I made a plugin for the ARRL Sweepstakes contests. Due to some minor changes you have to use RUMped version 2 Beta 37 or newer. Please download the full package here:
http://dl2rum.de/rumsoft/RUMpedBeta.zip
Has anyone been working on a plugin for this weekend's CQ WW RTTY WPX contest?
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
Rick,
I guess the rules for SSB/CW and RTTY are the same. There is no plug in required. The plug in does not support Prefixes as multipliers (yet).
I'm not sure abt. the points within North America.
I updated the corrected ver. 3 application. The WPX point calculation should be fine now for all modes.
http://www.dl2rum.de/rumsoft/RUMped.zip
