Page 3 of 3
Re: Some Questions / Features
Posted: Wed 26. May 2010, 08:18
F6FLU wrote:But I confirm; the Locator Field (and probably the IOTA Field too) is not updated when you click on different Calls into the Band Map Windows, when the Locator field is "set" the value don't change
Once again: These data are not changed or deleted automatically at this time. Maybe you have entered data before, this is to prevent data loss.
Posted: Wed 26. May 2010, 08:34
by F6FLU
Very Stange,
that means ,
1) I erase the Locator Field
2) I click on a call into the Band map and all fields are set in the Logging Mask and the Locator field is set (for example I click on TT8PK on 14005 mode CW , the Locator Field is set to "JK72MC"
3) I click now on an another call for example BD1TCC on 14013 mode CW
The Locator Field is not reseted and it is always set to JK72MC
If I save this QSO with BD1TCC this locator JK72MC is saved into the Log
And the Locator of BD1TCC is not JK72MC
I Know, I insiste but, I think theses Locator and IOTA Fields have to erased when you click on an another Call
Dan
Posted: Wed 26. May 2010, 08:46
The Locator field is filled only, when this station is always in the log with a known locator.
I'm a lazy guy: Sometimes I fill manually data like notes and locator and click later on the spot to fill the call sign.
It would be a good practice to press Command W before you click on a spot or into the band map. This clears all entries.
Posted: Wed 26. May 2010, 09:20
by F6FLU
DL2RUM wrote: It would be a good practice to press Command W before you click on a spot or into the band map. This clears all entries.
Yes perhaps but it is not very ergonomics !!
