CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
Re: CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
Issue is fixed. Bill G4JWS pointed me to the fact that in WSJT-X -> Preferences -> Radio -> Mode should be set to 'None'.
All working now.
All working now.
Funny how this board doesn't have the ability to delete your own account.
Fine, I will add a note in the docs.
Hmm, hard to track. Try this: http://dl2rum.de/RUMlogNG/TCP2Serial.zipEA3HOE wrote:Still crashes...
When it crashes again, please send me the full crash log as file, not just the pasted text.
This one works! "Unfortunately" my CAT issue is resolved already. I'll send you the details by personal mail so you can have a look at it and improve if needed.DL2RUM wrote:Hmm, hard to track. Try this: http://dl2rum.de/RUMlogNG/TCP2Serial.zip
I have a Kenwood TS570s and when using either JT65 or FT8 modes, after each transmission, my radio switches to LSB.
Also, when I change bands in WSJT-X, the radio changes to LSB. If I set the radio to USB, then change bands in WSJT-X, once again, it switches to LSB.
In WSJT-X preferences > Radio, I have Mode set to None and Split Operation set to None.
WSJT-X is successfully sending data to RumlogNG including the logging function.
Do I have something configured incorrectly?
- Attachments
- WSJT-X.tiff (109.29 KiB) Viewed 7851 times
73, Dave, VA3CP
Check your TRX settings in RUMlog. When WSJT-X is in command, it sets the mode you have selected in RUMlog for the PSK mode. USB Data should be here a good choice.
I checked the RumlogNG preferences and for TX 1, the PSK mode was already set to USB.
When I change the PSK mode to LSB, WSJT-X can change bands and will put the rig in USB mode. After each WSJT-X transmission, the TS570s sounds the CW letter F.
73, Dave, VA3CP
Do you use a TS570 or a TS590?
Okay, I've read everywhere TS-590 in this thread.
You are right, for the TS-570 LSB and USB is swapped for the PSK mode. It will be fixed in the next update. I can't see a reason for CW keying, maybe the WSJT-X function?
