RUMlog 3.7.8 ADIF, LoTW and eQSL bug fixing
Re: RUMlog 3.7.6 eQSL bugfixing
New in Ver. 3.7.5
A minor failure was fixed. The "Directions and Distances" window (Menu-->Window-->Sun/Distance Table) uses now your own grid square as origin, not the default one of your country.
Tnx to David, VA3MJR
New in Ver. 3.7.6
• A bug is fixed, which one allowed only 6 characters to be entered into the LoTW and eQSL password field in the preferences
• A bug in the eQSL window is fixed. This one made it impossible to use the automatic download feature, when no LoTW access data were entered in the preferences.
• ADIF import improvement: When a QSL record can not be imported into RUMlog, you will be informed about the reason.
Thanks to Gerrit, PA3BYA for the bug report.
Read the attached What's new??? file (http://dl2rum.de/rumsoft/rumlognews.html) in the RUMlog folder for further information.
Re: RUMlog 3.7.7 and qrz.com changes
qrz.com has changed the web site layout for few days ago. The RUMlog 3.7.7 will enable again the qrz.com call sign queries. The search for QSL info is still not available and the menu item is always disabled.
Thanks to Karl-Heinz, DF7KHK for the tip.
