arcix
Posts: 13 Joined: Sun 2. Sep 2012, 14:17
Unread post
by arcix » Sun 9. Jun 2013, 16:46
DL2RUM wrote: You should use the "Use CTS" option, rather than the "Set RTS line" option.
here it works just fine when either "Set RTS line" or "Use CTS" are set. It doesn't when both are unchecked.
Ulde IK2TYL
Posts: 3071 Joined: Mon 27. Aug 2007, 13:36
Unread post
by DL2RUM » Sun 9. Jun 2013, 17:23
It may work, but the connection will be more reliable when you use the correct handshake option.
The "Set xxx Line" option was introduced to power external interfaces.
KD8QWH
Posts: 5 Joined: Wed 20. Mar 2013, 23:06
Unread post
by KD8QWH » Mon 10. Jun 2013, 01:00
Thank you so much for your fantastic support. With your help I was able to get it to work. I greatly appreciate all your efforts.
God Bless
Anthony
KD8QWH
