Page 2 of 3
RUMlog 5.0.3 released
Posted: Sat 18. Aug 2012, 10:41
  • Option added to use the QSO Note as eQSL comment (RUMlog --> Preferences --> LoTW/eQSL tab)
  • Option added to save a log in a SOTA compatible format (Search-Window --> Save as SOTA File
  • Most of the menu entries disabled during QSO Editing to avoid interferences
  • Changes made in the K3 Control Window to be more useful for the KX3
Only the application file itself was changed.
Download the application only: http://dl2rum.de/rumsoft/RUMlogApp.zip
Re: RUMlog 5.0.4
Posted: Tue 28. Aug 2012, 22:09
K7PT has changed the dx database format, so the download was broken for few days ago. Version 5.04 will fix it.
Only the RUMlog application file itself was changed.
Download the full package: http://dl2rum.de/rumsoft/RUMlog.zip
Re: RUMlog 5.0.4
Posted: Mon 3. Sep 2012, 21:58
by EA6AZ
Hi Tom
I'm very interested in the US Counties, but some bugs or missing counties were found. The list of the counties is not the same that appears in QRZ.COM (for example ST. for Saint, and uppercase/lowercase . That comment is because to calculate the number of counties uppercase/lowercase are sensitive, giving a wrong number.
Take note that AZ,YAVAPAI county are missing.
Other point is if is possible to implement the opcion to save as .TXT or copy to the clipboard?
Thanks for great program.
73 Tano,EA6AZ
Re: RUMlog 5.0.4
Posted: Tue 4. Sep 2012, 10:01
I agree, this is a problem. There is no official county list to use. From one station you may find different spellings for the same County in qrz.com and in LoTW.
Please see it as operating aid, not as a tool to apply for the award. I will add the missing County.
BTW, you can edit the County list by yourself using a SQLite database tool. (MesaSQLite or SQLiteManager) The County table is within the IOTA.rsd database.
What do you want to export as text? Your worked/confirmed County table?
Re: RUMlog 5.0.5
Posted: Tue 4. Sep 2012, 10:27
Version 5.0.5 4-September 2012
  • Added missing County AZ, YAVAPAI
  • Sending TRX data to fldigi is working again, was broken for some transceivers
  • Option "Save spots to DX database" is back again, disappeared from the DX-Cluster Preference tab for an unknown reason.
The RUMlog application file and the IOTA.rsd database were changed.
Download the changed files only: http://dl2rum.de/rumsoft/RUMlogApp.zip
RUMlog 5.0.6
Posted: Sun 23. Sep 2012, 09:02
Version 5.0.6 22-September-2012
The PSK tone marker is back again in the Digi window.
Re: RUMlog 5.0.6
Posted: Wed 26. Sep 2012, 12:50
by NF4L
Great, Tom.
The second time I used PSK31, the interface flipped back and forth between PSK and RTTY at a rate of about once per second. I closed the interface window and got a message "An exception of class NilObjectException was not handled. The application must shut down.". Since re-starting RUMLog, it has performed perfectly.
73, Mike NF4L
RUMlog 5.0.7
Posted: Sun 30. Sep 2012, 18:57
Version 5.0.7 30-September-2012
  • Polish translation added. Tnx Daniel, SP2-04-0586
Re: RUMlog 5.0.8
Posted: Thu 25. Oct 2012, 14:49
Version 5.0.8 25-October-2012
  • Clublog uploads are now performed in the background
  • Use of new qrz.com server address (xml-subscription)
  • Minor fixes for zones calculation for UA and UA9
ICOM-706+microHAM USB Intface II+RUMlog 5.0.8
Posted: Sat 17. Nov 2012, 17:22
by dj4kw
In my 2nd QTH (not main station) tried to install RUMLog 5.0.8 on MACBook Pro, MAC OS X 10.6.8 connected to ICOM-706 MK IIG by microHAM USB Interface II (CAT and Key). RUMrouter can't open microHAM port. Is this a supported configuration or am I missing setup steps, software, or hardware?
