Clublog upload issue
HK3W
Re: Clublog upload issue
Unread post by HK3W »
I already did the tests and the synchronization isn't working like it used to.
Siso HK3W
Over the Station Info Box you will see the status with more or less useful information.
K7RAN
Unread post by K7RAN »
I found out that on October 2, 2025, Clublog only allows application-based uploads using a special app-only callsign that you must generate in your account settings under "App. Passwords"... If you log into Clublog, you can find that particular function here:
https://clublog.org/edituser.php?tab=7
So I can indeed confirm that I was able to fix the problem in RumLogNG. However QSO Upload Utility is still failing with Clublog. Details:
1) In RUMlogNG, in Settings, under the "Databases" tab, note the Clublog.org section at lower-right. For "User name," input your EMAIL ADDRESS (and NOT your callsign). Then for "Password" paste the new long string you generated for an "App. Password" in your Clublog settings. Then of course put your callsign in the "Callsign" field. Any synchronization problems should be fixed immediately.
2) However in QSO Upload Utility, inputting these same things (email address and the new app-based password) still results in errors for me. For that reason, I unchecked "Enable Uploads" for Clublog.org in QSO Upload Utility. Frankly, there's no need anyway since RUMLogNG is doing the work as well. I'm wondering though if QSO Upload Utility is having trouble with certain lengthy app-based passwords that Clublog creates for us. My app-based password is 37 characters which includes several hyphens.
I hope my observations help someone here.
73, Randy K7RAN
