Re: Some Questions / Features
Posted: Sun 23. May 2010, 11:35
Hi Tom
So I trying again with an example :
I click on a call in the DX Spot windows :
all fields on the Logging Mask are set (Call; QRG; Mode )
For example : I clicked on EA5IY in the DX Spot Windows and on the Logging Mask I have Call : EA5IY, QRG : 14160 ; Mode SSB
Now I Click (double click) on the Band Map on the GI7FHU his is on 14085 in CW mode, so my transceiver have switched on the 14085 and on CW mode, no problem for that
BUT on the Logging Mask only the Call has been modified, the Call EA5IY has ben deleted and Now I can see the GI7FHU on the field "Callsign, BUT the other fields QRG and Mode are still "14160" and "SSB" and Not "14085" and "CW"
I hope that is more clear with this example ?
Daniel
I can Explain exactly in English I Think;DL2RUM wrote:Hi DanielYou wrote, you have your trx connected. Mode and frequency should be set on the TRX, what causes the log to show the trx data.If I click, or if I double-clic on one call into the Band Map windows , only the Call will be transferred in the Logging mask, the QRG and Mode are not
Otherwise I could add the qrg/mode x-fer to the log when there is no TRX connected.
Daniel
