Some Questions / Features
F6FLU
Re: Some Questions / Features
Unread post by F6FLU »
Hi Tom
DL2RUM wrote:Hi Daniel
If I click, or if I double-clic on one call into the Band Map windows , only the Call will be transferred in the Logging mask, the QRG and Mode are not
You wrote, you have your trx connected. Mode and frequency should be set on the TRX, what causes the log to show the trx data.
Otherwise I could add the qrg/mode x-fer to the log when there is no TRX connected.
I can Explain exactly in English I Think;
So I trying again with an example :
I click on a call in the DX Spot windows :
all fields on the Logging Mask are set (Call; QRG; Mode )
For example : I clicked on EA5IY in the DX Spot Windows and on the Logging Mask I have Call : EA5IY, QRG : 14160 ; Mode SSB
Now I Click (double click) on the Band Map on the GI7FHU his is on 14085 in CW mode, so my transceiver have switched on the 14085 and on CW mode, no problem for that
BUT on the Logging Mask only the Call has been modified, the Call EA5IY has ben deleted and Now I can see the GI7FHU on the field "Callsign, BUT the other fields QRG and Mode are still "14160" and "SSB" and Not "14085" and "CW"
I hope that is more clear with this example ?
Daniel
Daniel - F6FLU
iMac 27" Intel Core i7 2,8 Ghz
Memory : 8 Go
French System : 10.6.3
http://F6FLU.fr
I understood, but this is not the way it should work. I guess there is a problem with your trx control. Which type of transceiver do you have connected? Do mode or frequency changes on the trx seen in the logging mask?
DK5LP
Unread post by DK5LP »
here is same Problem: TRX is K2.
The mode don't change in Logbook after double-click in the Bandmap. The TRX-Mode are changed.
vy 73
'Karl'-Heinz, DK5LP / AK5LP
:oops:
:( Then there must be a new bug! :cry: I'm out of home in these days, I have to investigate in the next week.
F6FLU
Hello
I use an FT 1000 MP Mark V
Daniel
Daniel - F6FLU
Memory : 8 Go
http://F6FLU.fr
I don't know when this function is broken. Now it should work again, please test it with your transceiver:
http://dl2rum.de/rumsoft/RUMlogBeta.zip
F6FLU
Hi Tom
Sorry, but that don't works (with the new beta version) ; the transceiver commute without any problem; but on the Logging Mask only the call has bee updated the other Fields are not updated
Daniel
Daniel - F6FLU
Memory : 8 Go
http://F6FLU.fr
What happens when you disconnect or disable the CAT control?
DK5LP
now, with 4.4.8 Beta3, it works perfect :D
Thanks for all ...
vy 73
F6FLU
Hello
YES that works fine now, I have somme Problem with the CAT , I do not Know while, Now the pooling is OK and that works fine
The next step for me is to try to have one QSO in Digital mode with CocoaModem, I have to read carefully the documentation about that :-)
But I confirm; the Locator Field (and probably the IOTA Field too) is not updated when you click on different Calls into the Band Map Windows, when the Locator field is "set" the value don't change
Dan
Daniel - F6FLU
Memory : 8 Go
http://F6FLU.fr
