Without wires etc IC-705
KC9WIB
Re: Without wires etc IC-705
Unread post by KC9WIB »
I resolved my choppy signal issue
It's very important to use the audio midi setup utility and set the sample rate to 48khz
This solved my issue with both without wires and wfview
I was using black hole and sound flower and setting the rate to 48k made the issue disappear
Now I have a smooth and clean and strong signal
I used blackhole today - I assume same solution for soundflower
Also check on restarts of the computer- it might reset
kf5wor
Unread post by kf5wor »
for the folks that have WithoutWires connected successfully to js8call - what rig type are you selecting in js8call?
I've got audio flowing through to my ic-705, but no CAT control.
Doesn't js8call support the IC-705?
kf5wor
using version 2.2.0 for mac, I don't see a listing for the ic-705 in the rig dropdown list.
i was under the impression that WithoutWire could forward cat control commands to the ic-705 over the wifi connection. is this incorrect?
Yes, you are correct.
kf5wor
ahh - i think i was missing that WithoutWire is exposing a TCP server that speaks the same protocol as the radio it's connecting to - not something like hamlib, correct?
It's just a relay, no intelligence inside.
