Page 2 of 2
Re: Change QSL status of multiple QSOs
Posted: Sun 11. Oct 2020, 16:11
by K8AJS
K8AJS wrote: ↑Sun 11. Oct 2020, 15:54
DL2RUM wrote: ↑Sun 11. Oct 2020, 13:30 I made a test log with 210.000 QSOs. Now I can notice a hung, pending on the number of affected QSOs. While editing a QSO with S01 doesn't show any delay, there is a hung of up to eight seconds when editing a QSO with a DL station (22.000 Qs in the log)
I addressed a performance problem and made few improvements, check this please and report: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
I checked and, based on the number of affected QSOs (selecting based on the DXCC of the QSO), I changed a couple of the affected QSOs with W1AW (there are 94,510 log entries for DXCC K) and then I made a change in a QSO with an HL (59 log entries for HL in my log). There was virtually no difference in the time required, they both took a duration of 20 to 25 seconds to complete.
Hope this helps.
Let me change that, based on a different discovery. The changes that I made that had times the same as I had before were done using the logbook mask in the Search QSOs window. If I make the same type of change in the main log window, the times are much shorter. I did a change on an S50 callsign (1678 QSOs in the log) working in the main log window, and the time required was next to nothing.
Hope this helps.
Posted: Sun 11. Oct 2020, 16:22
by K8AJS
K8AJS wrote: ↑Sun 11. Oct 2020, 16:11
Hope this helps.
But on further checks using W1AW, the time is still very long, in the 20 second range. Of course, that K DXCC probably affects more log entries than some of the other items, so maybe that is an area to look for the problem.
Posted: Sun 11. Oct 2020, 16:32
Concerning your root problem: You could manipulate your logbook file directly using a SQLite database tool. Somethings like this:
update logbook set qsl = "W" where qsl = "R"
After that, you have to recalculate your DXCC status using the Logbook menu.
Posted: Sun 11. Oct 2020, 17:01
by K8AJS
DL2RUM wrote: ↑Sun 11. Oct 2020, 16:03
Hope this helps.
Not really. Could you e-mail me your log file for further investigations?
OK, I'll attach It to an email and send it your way.
