Page 2 of 3
Re: RUMlogNG version 4.4
Posted: Tue 1. Oct 2019, 22:26
by fpz
When double-clicking on a frequency in the DX Spots window WSJT-X updates the DX Call field with the correct callsign and generates standard messages.
Posted: Tue 1. Oct 2019, 22:36
by DL2RUM_Tom
But does the trx change mode and frequency?
Posted: Tue 1. Oct 2019, 22:44
by fpz
I'm not entirely sure I got the question right, if it's about the transceiver's application (ExpertSDR2 SunSDR2 1.3.0 RC4), then no/yes: the mode does not update (stays on whatever is selected instead of switching to DIGU) but the frequency updates.
Posted: Tue 1. Oct 2019, 22:52
by fpz
While typing this it occurred to me that the ExpertSDR2 application was updated recently, too, so I went back to ExpertSDR2 1.2.0 but the issue remains with the same symptoms.
Posted: Wed 2. Oct 2019, 04:37
by LA0FA
Yes, the rig control from RumLogNG to radio still works as it should .. its the control of frequency from Wsjt-x which is the problem only. my email:
matpet@icloud.com
Posted: Tue 8. Oct 2019, 01:15
by VE3MM
Hi Tom
I am experiencing the same problems as "fpz". Equipment is the same as "fpz" as well, Sunsdr2pro. WSJT no longer has frequency connection to RUMlogNG.
This worked before the most recent update to 4.4
If there is any information that I can supply to help diagnose this please let me know.
Rick ve3mm
Posted: Tue 8. Oct 2019, 02:05
Hi Rick,
It seems we fixed that. Pse try it out and report back:
Posted: Thu 10. Oct 2019, 01:59
by VE3MM
Hi Tom
Yes you did fix it! Just in time for me to work A82Z on 80m FT8 fox and hound mode.
WSJT-X sees the frequency of the Sunsdr via the RumlogNG connection. Beautiful.
Thanks for the update.
Rick ve3mm
RUMlogNG version 4.4.1
Posted: Thu 10. Oct 2019, 10:29
RUMlogNG 4.4.1 is available for direct download here:
http://dl2rum.de/RUMlogNG/RUMlogNG.zip
Available in the App Store soon:
https://itunes.apple.com/app/rumlogng/id964454561?mt=12
What's new?
- Fix: Bug in Icom Auto Discovery when you have connected two Icom transceivers - Tnx Wolfgang, DL1IE
- Fix: Bug in the TCI CAT protocol - Tnx Frank, DF8FF
- Fix: Bug in the DXLab Suite Commander Server - Tnx Mat, LA0FA
- New: Support for qrz.ru
Re: RUMlogNG version 4.4.1
Posted: Sun 20. Oct 2019, 20:40
by ea5xq
Hi
I am facing some troubles since last update.
1.- DX Spots does not show any spot
2.- Opening Preferences takes more than 15 secs with spinning ball.
3.- If I choose a QSO (double click) spinning ball appears
I have downloaded 4.4.1 and reinstall it but not success
