Yes, that works. For example, when i click on the bandplan or DX Spots the radio follows.DL2RUM wrote:Does the radio follow RUMlog? Can you command the radio to QSY?Radio doesn't follow the band change in WSJT-X.
CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
Re: 3.7?
Funny how this board doesn't have the ability to delete your own account.
Re: 3.7?
I don't have a Kenwood available. I tested the TS-590S interface with my KX3, without any problems. The KX3 reacts like a Kenwood for the major CAT commands.
We should wait for other Kenwood users.
Re: 3.7 CAT control WSJT-X and Kenwood TS-590S
Ok. No big issue for me at the moment. Just an inconvenience. BTW, i tried to run TCP2Serial you gave me a long time ago, but this crashes on start. Maybe something went corrupt. Maybe it just doesn't run on Sierra. Have you ever encountered that?
Ton.
Ton.
Re: CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
Yes, here it crashes since I use ipV6 local here.
No IPV6 here, so it must be something else.
Maybe. In fact, getting the external ip address lets the app crash. Do you need an update?
If you have one, yes please. Maybe i can troubleshoot the issue i'm having.DL2RUM wrote:Maybe. In fact, getting the external ip address lets the app crash. Do you need an update?
Still crashes...
Process: TCP2Serial [3676]
Path: /Applications/TCP2Serial.app/Contents/MacOS/TCP2Serial
Identifier: de.dl2rum.TCP2Serial
Version: 1.1.4 (6)
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: TCP2Serial [3676]
User ID: 1829133891
Date/Time: 2017-08-30 19:05:05.591 +0200
OS Version: Mac OS X 10.12.6 (16G29)
Report Version: 12
Anonymous UUID: A8C78AFA-A78D-C0F6-E7F5-2E3AA66A857B
Time Awake Since Boot: 10000 seconds
System Integrity Protection: enabled
Crashed Thread: 6
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Exception Note: EXC_CORPSE_NOTIFY
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Invalid parameter not satisfying: aString != nil'
terminating with uncaught exception of type NSException
abort() called
Application Specific Backtrace 1:
0 CoreFoundation 0x00007fffa58042cb __exceptionPreprocess + 171
1 libobjc.A.dylib 0x00007fffba61448d objc_exception_throw + 48
2 CoreFoundation 0x00007fffa5809042 +[NSException raise:format:arguments:] + 98
3 Foundation 0x00007fffa7251be0 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 195
4 AppKit 0x00007fffa32a0dcd -[NSCell _objectValue:forString:errorDescription:] + 177
5 AppKit 0x00007fffa32a0c72 -[NSCell setStringValue:] + 41
6 AppKit 0x00007fffa334f91e -[NSControl setStringValue:] + 135
7 TCP2Serial 0x000000010a2f04b7 TCP2Serial + 46263
8 Foundation 0x00007fffa719d8ad __NSThread__start__ + 1243
9 libsystem_pthread.dylib 0x00007fffbb11393b _pthread_body + 180
10 libsystem_pthread.dylib 0x00007fffbb113887 _pthread_body + 0
11 libsystem_pthread.dylib 0x00007fffbb11308d thread_start + 13
Thread 0:: Dispatch queue: com.apple.main-thread
0 libsystem_kernel.dylib 0x00007fffbb02134a mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fffbb020797 mach_msg + 55
2 com.apple.SkyLight 0x00007fffb73073b7 SLSDisplayGetRefreshTiming + 212
3 com.apple.AppKit 0x00007fffa393a3e9 +[NSDisplayTiming(NSDisplayTimingCreation) displayTimingForScreenNumber:] + 17
4 com.apple.AppKit 0x00007fffa36a5941 __37+[NSDisplayCycle currentDisplayCycle]_block_invoke.31 + 467
5 com.apple.CoreFoundation 0x00007fffa5799d37 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
6 com.apple.CoreFoundation 0x00007fffa5799ca7 __CFRunLoopDoObservers + 391
7 com.apple.CoreFoundation 0x00007fffa577a6d9 __CFRunLoopRun + 873
8 com.apple.CoreFoundation 0x00007fffa577a114 CFRunLoopRunSpecific + 420
9 com.apple.HIToolbox 0x00007fffa4cdaebc RunCurrentEventLoopInMode + 240
10 com.apple.HIToolbox 0x00007fffa4cdabf9 ReceiveNextEventCommon + 184
11 com.apple.HIToolbox 0x00007fffa4cdab26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
12 com.apple.AppKit 0x00007fffa3273a54 _DPSNextEvent + 1120
13 com.apple.AppKit 0x00007fffa39ef7ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
14 com.apple.AppKit 0x00007fffa32683db -[NSApplication run] + 926
15 com.apple.AppKit 0x00007fffa3232e0e NSApplicationMain + 1237
16 libdyld.dylib 0x00007fffbaefa235 start + 1
Thread 1:
0 libsystem_kernel.dylib 0x00007fffbb02944e __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fffbb113621 _pthread_wqthread + 1426
2 libsystem_pthread.dylib 0x00007fffbb11307d start_wqthread + 13
Thread 2:
Thread 3:
1 libsystem_pthread.dylib 0x00007fffbb11348e _pthread_wqthread + 1023
Thread 4:: Dispatch queue: NSCGSDisableUpdates
2 com.apple.SkyLight 0x00007fffb72b4aaf _CGSReenableUpdateForConnectionSync + 99
3 com.apple.SkyLight 0x00007fffb72c3dce CGSUpdateManager::enable_update(unsigned long long) + 532
4 libdispatch.dylib 0x00007fffbaecd524 _dispatch_call_block_and_release + 12
5 libdispatch.dylib 0x00007fffbaec48fc _dispatch_client_callout + 8
6 libdispatch.dylib 0x00007fffbaeda9a0 _dispatch_queue_serial_drain + 896
7 libdispatch.dylib 0x00007fffbaecd306 _dispatch_queue_invoke + 1046
8 libdispatch.dylib 0x00007fffbaed3020 _dispatch_queue_override_invoke + 369
9 libdispatch.dylib 0x00007fffbaec66b5 _dispatch_root_queue_drain + 476
10 libdispatch.dylib 0x00007fffbaec648c _dispatch_worker_thread3 + 99
11 libsystem_pthread.dylib 0x00007fffbb1135a2 _pthread_wqthread + 1299
12 libsystem_pthread.dylib 0x00007fffbb11307d start_wqthread + 13
Thread 5:
Thread 6 Crashed:
0 libsystem_kernel.dylib 0x00007fffbb028d42 __pthread_kill + 10
1 libsystem_pthread.dylib 0x00007fffbb116457 pthread_kill + 90
2 libsystem_c.dylib 0x00007fffbaf8e420 abort + 129
3 libc++abi.dylib 0x00007fffb9ae194a abort_message + 266
4 libc++abi.dylib 0x00007fffb9b06c2f default_terminate_handler() + 267
5 libobjc.A.dylib 0x00007fffba6166fe _objc_terminate() + 103
6 libc++abi.dylib 0x00007fffb9b03d49 std::__terminate(void (*)()) + 8
7 libc++abi.dylib 0x00007fffb9b037be __cxa_throw + 121
8 libobjc.A.dylib 0x00007fffba6145b6 objc_exception_throw + 345
9 com.apple.CoreFoundation 0x00007fffa5809042 +[NSException raise:format:arguments:] + 98
10 com.apple.Foundation 0x00007fffa7251be0 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 195
11 com.apple.AppKit 0x00007fffa32a0dcd -[NSCell _objectValue:forString:errorDescription:] + 177
12 com.apple.AppKit 0x00007fffa32a0c72 -[NSCell setStringValue:] + 41
13 com.apple.AppKit 0x00007fffa334f91e -[NSControl setStringValue:] + 135
14 de.dl2rum.TCP2Serial 0x000000010a2f04b7 0x10a2e5000 + 46263
15 com.apple.Foundation 0x00007fffa719d8ad __NSThread__start__ + 1243
16 libsystem_pthread.dylib 0x00007fffbb11393b _pthread_body + 180
17 libsystem_pthread.dylib 0x00007fffbb113887 _pthread_start + 286
18 libsystem_pthread.dylib 0x00007fffbb11308d thread_start + 13
Thread 7:: com.apple.NSURLConnectionLoader
2 com.apple.CoreFoundation 0x00007fffa577b434 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fffa577a8c1 __CFRunLoopRun + 1361
4 com.apple.CoreFoundation 0x00007fffa577a114 CFRunLoopRunSpecific + 420
5 com.apple.CFNetwork 0x00007fffa48b7734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6 com.apple.Foundation 0x00007fffa719d8ad __NSThread__start__ + 1243
7 libsystem_pthread.dylib 0x00007fffbb11393b _pthread_body + 180
8 libsystem_pthread.dylib 0x00007fffbb113887 _pthread_start + 286
9 libsystem_pthread.dylib 0x00007fffbb11308d thread_start + 13
Thread 6 crashed with X86 Thread State (64-bit):
rax: 0x0000000000000000 rbx: 0x0000000000000006 rcx: 0x0000700006b1b3d8 rdx: 0x0000000000000000
rdi: 0x0000000000009f03 rsi: 0x0000000000000006 rbp: 0x0000700006b1b400 rsp: 0x0000700006b1b3d8
r8: 0x00007fffbafb7650 r9: 0x00007fffbaf79a50 r10: 0x0000000008000000 r11: 0x0000000000000206
r12: 0x0000700006b1b560 r13: 0x0000000000000030 r14: 0x0000700006b1d000 r15: 0x0000000000000008
rip: 0x00007fffbb028d42 rfl: 0x0000000000000206 cr2: 0x00007fffc3df0128
Logical CPU: 0
Error Code: 0x02000148
Trap Number: 133
Binary Images:
0x10a2e5000 - 0x10a2fcffb +de.dl2rum.TCP2Serial (1.1.4 - 6) <5B442610-17B7-31D1-B814-8D55E088EE27> /Applications/TCP2Serial.app/Contents/MacOS/TCP2Serial
0x10f8c9000 - 0x10fa6ffff GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x10faae000 - 0x10fffdff7 com.apple.driver.AppleIntelBDWGraphicsGLDriver (10.25.17 - 10.2.5) <8633C1AB-7008-3B8B-8D6D-8E1DE49DD265> /System/Library/Extensions/AppleIntelBDWGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelBDWGraphicsGLDriver
0x110218000 - 0x110242fff GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0x11024c000 - 0x1102cbff7 com.apple.driver.AppleIntelBDWGraphicsMTLDriver (10.25.17 - 10.2.5) <20DB0471-534D-3570-9E5A-AB052CF54E68> /System/Library/Extensions/AppleIntelBDWGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelBDWGraphicsMTLDriver
0x118ace000 - 0x118b0bdc7 dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
0x7fffa224f000 - 0x7fffa224ffff com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fffa2250000 - 0x7fffa2267ffb libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
0x7fffa2268000 - 0x7fffa2781feb com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fffa2782000 - 0x7fffa28f3ff3 libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fffa28f4000 - 0x7fffa2908ffb libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
0x7fffa2909000 - 0x7fffa2cfffef libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fffa2d00000 - 0x7fffa2d16fff libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fffa2d17000 - 0x7fffa2d1dfff libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
0x7fffa2d1e000 - 0x7fffa2d32ff7 libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
0x7fffa2d33000 - 0x7fffa2ebafe7 libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fffa2ebb000 - 0x7fffa2f6dfff libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fffa2f6e000 - 0x7fffa2f6efff com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fffa322d000 - 0x7fffa4006ff3 com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fffa4018000 - 0x7fffa4018fff com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fffa4019000 - 0x7fffa4087ff7 com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fffa4121000 - 0x7fffa4250ff7 libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fffa4251000 - 0x7fffa429bfff libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fffa42f8000 - 0x7fffa432bfff libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x7fffa4398000 - 0x7fffa4442ff7 com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fffa4443000 - 0x7fffa4494fff com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fffa4495000 - 0x7fffa44a4ff3 com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fffa44a5000 - 0x7fffa44f2fff com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fffa44f3000 - 0x7fffa452efff com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fffa452f000 - 0x7fffa453afff com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fffa453b000 - 0x7fffa4747ff7 com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fffa4748000 - 0x7fffa4748fff com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fffa48b1000 - 0x7fffa4c8bfff com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fffa4caa000 - 0x7fffa4fb3fff com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fffa4fbe000 - 0x7fffa5055ff3 com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fffa5076000 - 0x7fffa507cff7 com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fffa52a7000 - 0x7fffa5334fff com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fffa5335000 - 0x7fffa5348fff com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fffa5349000 - 0x7fffa5644fff com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fffa5645000 - 0x7fffa56f2ff7 com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
0x7fffa56f3000 - 0x7fffa5b8cff7 com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fffa5b8d000 - 0x7fffa620ffff com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fffa6210000 - 0x7fffa6453ffb com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fffa65b8000 - 0x7fffa65b8fff com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fffa65b9000 - 0x7fffa660afff com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fffa660b000 - 0x7fffa68e6ff7 com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fffa68e7000 - 0x7fffa691afff com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fffa691b000 - 0x7fffa6923ff3 com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fffa6924000 - 0x7fffa6a90ff7 com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fffa6a91000 - 0x7fffa6b41ffb com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fffa6b42000 - 0x7fffa6ba1fff com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fffa6ba2000 - 0x7fffa6c12fff com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fffa6c13000 - 0x7fffa6c58ff7 com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
0x7fffa6ce1000 - 0x7fffa6e2effb com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fffa6e2f000 - 0x7fffa6e64ff3 com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fffa6e65000 - 0x7fffa6ed6ffb com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fffa6fd4000 - 0x7fffa6fd9fff com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fffa716b000 - 0x7fffa7511fff com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fffa753d000 - 0x7fffa756eff7 com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fffa762e000 - 0x7fffa76d1fff com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fffa76d2000 - 0x7fffa7768ff7 com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fffa7769000 - 0x7fffa776fffb com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fffa77c2000 - 0x7fffa7922fef com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fffa7923000 - 0x7fffa7927fff libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fffa7928000 - 0x7fffa7a18ff7 libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fffa7a19000 - 0x7fffa7a3cffb libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fffa7a3d000 - 0x7fffa7a64ff7 libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fffa7a65000 - 0x7fffa7a67ff3 libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fffa7a68000 - 0x7fffa7ab6ffb libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fffa881f000 - 0x7fffa8838ff7 com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fffa9018000 - 0x7fffa9073fff com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
0x7fffa995c000 - 0x7fffa9964fff com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fffa9b3b000 - 0x7fffa9b43ff7 libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fffa9b44000 - 0x7fffa9b92ff3 com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fffa9b93000 - 0x7fffa9bacffb com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fffa9bad000 - 0x7fffa9bb8ff7 com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fffa9bb9000 - 0x7fffa9bbbfff libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fffa9bbc000 - 0x7fffa9bbfff7 libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x7fffa9bc0000 - 0x7fffa9bc4fff libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fffa9bc5000 - 0x7fffa9bceff7 libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fffa9bcf000 - 0x7fffa9bdafff libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fffa9bdb000 - 0x7fffa9c17ff7 libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fffa9c18000 - 0x7fffa9d8eff3 libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x7fffa9d8f000 - 0x7fffa9dd0ff7 libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fffaa738000 - 0x7fffaa746fff com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fffab298000 - 0x7fffab498fff com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fffab9ff000 - 0x7fffabd01ff7 com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fffabd02000 - 0x7fffabd77fff com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fffabda2000 - 0x7fffabda5ff3 com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fffac12c000 - 0x7fffac19bff7 com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fffaea1c000 - 0x7fffaea3effb com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fffaea3f000 - 0x7fffaea4efeb com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fffaeb3c000 - 0x7fffaebc797f com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fffaeffa000 - 0x7fffaf078ff7 com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fffafd03000 - 0x7fffafd2aff3 com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fffb064f000 - 0x7fffb0658ffb com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fffb0da1000 - 0x7fffb0db1fff com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
0x7fffb10ec000 - 0x7fffb111cff3 com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fffb13ad000 - 0x7fffb143cff7 com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fffb143d000 - 0x7fffb157cfe7 com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fffb157d000 - 0x7fffb164dff3 com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
0x7fffb169d000 - 0x7fffb1702ff3 com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fffb1703000 - 0x7fffb1711ff7 com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fffb1783000 - 0x7fffb178dffb com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
0x7fffb178e000 - 0x7fffb1792ff3 com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
0x7fffb17c8000 - 0x7fffb183dffb com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fffb1879000 - 0x7fffb18b8fff com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fffb18b9000 - 0x7fffb19cafff com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fffb1cb2000 - 0x7fffb20e3ff7 com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fffb343a000 - 0x7fffb343afff libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
0x7fffb3447000 - 0x7fffb3452ff3 libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
0x7fffb370b000 - 0x7fffb3727fff com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fffb3e38000 - 0x7fffb3eaeff3 com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fffb44c9000 - 0x7fffb44d0ffb com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
0x7fffb44d2000 - 0x7fffb44e6ff7 com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
0x7fffb44e7000 - 0x7fffb4509fff com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fffb45f0000 - 0x7fffb47a7fff com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fffb50c8000 - 0x7fffb5141ff7 com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
0x7fffb52bc000 - 0x7fffb52e4ff7 com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fffb5396000 - 0x7fffb53a1fff com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fffb5c79000 - 0x7fffb5cbaff3 com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fffb63a2000 - 0x7fffb63bcfff com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fffb63d5000 - 0x7fffb63f8ff3 com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fffb7154000 - 0x7fffb71e1fff com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fffb7202000 - 0x7fffb7468feb com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
0x7fffb7647000 - 0x7fffb7653ff7 com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
0x7fffb7d3f000 - 0x7fffb7db3fdf com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fffb81f2000 - 0x7fffb81f8ff7 com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fffb8284000 - 0x7fffb834aff7 com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
0x7fffb83be000 - 0x7fffb83bffff com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fffb83c0000 - 0x7fffb8550ff3 com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fffb9601000 - 0x7fffb9603ffb com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fffb9658000 - 0x7fffb9673ff7 libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
0x7fffb9674000 - 0x7fffb967ffff libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
0x7fffb9711000 - 0x7fffb9712ff3 libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fffb9713000 - 0x7fffb9926fff libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
0x7fffb994a000 - 0x7fffb994afff libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
0x7fffb994b000 - 0x7fffb994fffb libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
0x7fffb9950000 - 0x7fffb9951ffb libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
0x7fffb99bd000 - 0x7fffb99e8ff3 libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
0x7fffb99e9000 - 0x7fffb9a65fc7 libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
0x7fffb9a69000 - 0x7fffb9a69ff3 libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
0x7fffb9a6a000 - 0x7fffb9a7aff3 libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
0x7fffb9a7b000 - 0x7fffb9a89ff7 libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
0x7fffb9a8a000 - 0x7fffb9ae0ff7 libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
0x7fffb9ae1000 - 0x7fffb9b0aff7 libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
0x7fffb9b0b000 - 0x7fffb9b1bffb libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
0x7fffb9b1c000 - 0x7fffb9b32fcf libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
0x7fffb9b33000 - 0x7fffb9b33ff7 libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
0x7fffb9b34000 - 0x7fffb9b35ff3 libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
0x7fffb9bef000 - 0x7fffb9cd4ff7 libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
0x7fffb9e72000 - 0x7fffb9ec5ff7 libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
0x7fffb9f42000 - 0x7fffb9f42fff libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
0x7fffb9f52000 - 0x7fffb9f57ff7 libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
0x7fffb9f58000 - 0x7fffba04aff7 libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
0x7fffba04b000 - 0x7fffba270ffb libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
0x7fffba276000 - 0x7fffba277fff liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
0x7fffba278000 - 0x7fffba291ffb liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
0x7fffba292000 - 0x7fffba2a8ff7 libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
0x7fffba2a9000 - 0x7fffba551ff7 libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
0x7fffba584000 - 0x7fffba5feff3 libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
0x7fffba5ff000 - 0x7fffba9d1047 libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
0x7fffba9d4000 - 0x7fffba9d8fff libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
0x7fffba9d9000 - 0x7fffbaa0afff libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
0x7fffbaa27000 - 0x7fffbaa43ffb libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
0x7fffbaa93000 - 0x7fffbabe1ff7 libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
0x7fffbacd6000 - 0x7fffbace3fff libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
0x7fffbace4000 - 0x7fffbadd3fff libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
0x7fffbadd4000 - 0x7fffbadfdfff libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
0x7fffbadfe000 - 0x7fffbae0fff3 libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
0x7fffbae1e000 - 0x7fffbae22ff7 libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
0x7fffbae23000 - 0x7fffbae2dfff libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
0x7fffbae2e000 - 0x7fffbae35fff libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
0x7fffbae36000 - 0x7fffbae3efff libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
0x7fffbae3f000 - 0x7fffbaec2fdf libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
0x7fffbaec3000 - 0x7fffbaef4fff libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
0x7fffbaef5000 - 0x7fffbaefaffb libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
0x7fffbaefb000 - 0x7fffbaefbffb libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
0x7fffbaefc000 - 0x7fffbaf08fff libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
0x7fffbaf09000 - 0x7fffbaf09fff liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
0x7fffbaf0a000 - 0x7fffbaf0fff3 libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
0x7fffbaf10000 - 0x7fffbaf12ff3 libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
0x7fffbaf13000 - 0x7fffbaf14ffb libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
0x7fffbaf15000 - 0x7fffbaf2dff7 libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
0x7fffbaf2e000 - 0x7fffbaf2eff7 libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
0x7fffbaf2f000 - 0x7fffbafbcfef libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
0x7fffbafbd000 - 0x7fffbafc0ffb libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
0x7fffbafc1000 - 0x7fffbafc4fff libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
0x7fffbafc5000 - 0x7fffbafddfff libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
0x7fffbafde000 - 0x7fffbafe4fff libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
0x7fffbafe5000 - 0x7fffbb00eff7 libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
0x7fffbb00f000 - 0x7fffbb031ff7 libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
0x7fffbb032000 - 0x7fffbb079fe7 libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
0x7fffbb07a000 - 0x7fffbb098ff7 libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
0x7fffbb099000 - 0x7fffbb0f2ffb libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
0x7fffbb0f3000 - 0x7fffbb0fcff3 libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
0x7fffbb0fd000 - 0x7fffbb106ff3 libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
0x7fffbb107000 - 0x7fffbb10ffe7 libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
0x7fffbb110000 - 0x7fffbb11aff7 libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
0x7fffbb11b000 - 0x7fffbb11eff7 libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
0x7fffbb11f000 - 0x7fffbb120ff3 libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
0x7fffbb121000 - 0x7fffbb128ffb libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
0x7fffbb129000 - 0x7fffbb13cff7 libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
0x7fffbb13d000 - 0x7fffbb142ffb libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
0x7fffbb143000 - 0x7fffbb16cff7 libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 6262
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=249.8M resident=0K(0%) swapped_out_or_unallocated=249.8M(100%)
Writable regions: Total=131.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=131.6M(100%)
VIRTUAL REGION
REGION TYPE SIZE COUNT (non-coalesced)
Accelerate framework 256K 3
Activity Tracing 256K 2
CG backing stores 8540K 5
CG image 84K 9
CoreAnimation 84K 8
CoreUI image data 2876K 14
CoreUI image file 184K 5
Kernel Alloc Once 8K 2
MALLOC 92.4M 41
MALLOC guard page 48K 10
Memory Tag 242 12K 2
SQLite page cache 64K 2
STACK GUARD 56.0M 9
Stack 11.6M 9
VM_ALLOCATE 112K 15
__DATA 20.6M 206
__GLSLBUILTINS 2588K 2
__IMAGE 528K 2
__LINKEDIT 116.2M 8
__TEXT 133.6M 206
__UNICODE 556K 2
mapped file 55.4M 14
shared memory 16.4M 12
TOTAL 517.9M 565
Model: MacBookPro12,1, BootROM MBP121.0167.B33, 2 processors, Intel Core i7, 3,1 GHz, 16 GB, SMC 2.28f7
Graphics: Intel Iris Graphics 6100, Intel Iris Graphics 6100, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445424533303445422D45474346202020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445424533303445422D45474346202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.21.171.130.1a1)
Bluetooth: Version 5.0.5f1, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Thunderbolt Ethernet, Ethernet, en4
Network Service: Parallels Shared #0, Ethernet, vnic0
Network Service: Parallels Host-Only #1, Ethernet, vnic1
PCI Card: Apple 57762-A0, Ethernet Controller, Thunderbolt@195,0,0
Serial ATA Device: APPLE SSD SM0256G, 251 GB
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: USB3.0 dual display
USB Device: External USB 3.0
USB Device: Bluetooth USB Host Controller
USB Device: USB2.0 Hub
USB Device: Hub
USB Device: CP2102 USB to UART Bridge Controller
USB Device: USB Audio CODEC
USB Device: USB-Serial Controller D
USB Device: Vendor-Specific Device
USB Device: USB Storage
USB Device: Samsung S2 Portable
USB Device: Jabra UC VOICE 750a MS
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
Thunderbolt Device: Thunderbolt to Gigabit Ethernet Adapter, Apple Inc., 3, 5.5
