contest mode
hanz
contest mode
Unread post by hanz »
Hello Tom,
Something strange i can't solve.
I am in the contest window.
Running mode it sends after pressing F1 some parts of the cq test string, random parts.
In search mode it sends up to the first digit of the number i.e. 001 it sends only the first zero and stops.
i have no idea, been trough the settings and restarted the computer and radio etc..
hanz. YL3JD
Re: contest mode
Which kind of cw keyer?
hanz
Re: contest mode
I am using rumlug connected to the radio-> Cw interface transceiver.
CAT:Icom server
hanz
Re: contest mode
problem is the same when using cwtools
Re: contest mode
Tnx for the hint Hanz, I can confirm this issue.
Use try this version and report: https://dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
hanz
Re: contest mode
Thanks Tom,
Yes, when i switch between the test version and the "old" version, the test version is OK and the old version is with the problem.
You nailed it !
73 und alles gute
hanz YL3JD
