Dr Tom,
Since a month Rumlog just hangs, beachball all te time .\I have to reboot the computer.
No idea why.
When i kill the rumlog proces and i want to start rumlog again it doesn't start up. Need to reboot the computer. (M2 mac mini)
I have the dump if you need it.
Radio's icom7300 and icom7610 with both connected it happens.
73 hanz YL3JD
Date/Time: 2025-07-14 14:35:13.852 +0300
End time: 2025-07-14 14:36:24.959 +0300
OS Version: macOS 15.5 (Build 24F74)
Architecture: arm64e
Report Version: 60
Incident Identifier: 39742AB5-2A11-436A-91C6-0EA7DEBD172C
Data Source: Stackshots
Shared Cache: D7397D7F-8DF9-3920-81A7-C0A144BE9C51 slid base address 0x1892dc000, slide 0x92dc000 (System Primary)
Shared Cache: CA9782E8-A954-3134-81A4-A7C6CB9CA2BD slid base address 0x185360000, slide 0x5360000 (DriverKit)
Shared Cache: 6E28F2B9-5B29-30C6-AF7C-47D23BF9EC34 slid base address 0x7ff80e2e8000, slide 0xe2e8000 (Rosetta)
Command: RUMlogNG
Path: /Applications/RUMlogNG.app/Contents/MacOS/RUMlogNG
Identifier: de.dl2rum.RUMlogNG
Version: 5.19.5 (686)
Team ID: 347RZE9T64
App Item ID: 964454561
App External ID: 876007969
Is First Party: No
Beta Identifier: 686B8403-EAE3-5BA4-867E-F6B4955BD25D
Architecture: arm64
Parent: launchd [1]
PID: 811
Time Since Fork: 26906s
Event: hang
Duration: 71.11s
Duration Sampled: 1.50s (process was unresponsive for 70 seconds before sampling)
Steps: 15 (100ms sampling interval)
hang
Re: hang
Thanks Tom,
I now unchecked CAT.
I thisnki ones installed a driver for communicating with QMX but i am not sure.
I try to look for a driver i used kextstat but did not see anything that looks like a syllabs driver or some thing like that.
I wait for my Wifi bridge so i can connect 7610 via wifi and do noyt need the cat. For now i check the behaviour with cat unchecked.
hanz
hanz
Re: hang
The only "thing" i could find under disabled software in the system profiler is this:
EG27766DY7 - com.silabs.driver.CP210xVCPDriver64:
Version: 3.0.0d1
Reason: No User Consent
Date Disabled: Unknown
I keep the CAT disabled and see if the hanging happens again.
Version: 3.0.0d1
Re: hang
Hello Tom,
RL just hang. Now i do not use the comport all via TCP.
Hereby partly the dump from the exception.
I had the waterfall open, mainlog and control window.
73 hanz
Date/Time: 2025-07-22 18:21:34.389 +0300
End time: 2025-07-22 18:21:35.458 +0300
Report Version: 60
Incident Identifier: D30C17F1-ACF6-46A8-AAEE-D69A2CB808E8
Shared Cache: D7397D7F-8DF9-3920-81A7-C0A144BE9C51 slid base address 0x1817dc000, slide 0x17dc000 (System Primary)
Shared Cache: CA9782E8-A954-3134-81A4-A7C6CB9CA2BD slid base address 0x19944c000, slide 0x1944c000 (DriverKit)
Shared Cache: 6E28F2B9-5B29-30C6-AF7C-47D23BF9EC34 slid base address 0x7ff80cbbc000, slide 0xcbbc000 (Rosetta)
Command: RUMlogNG
Team ID: 347RZE9T64
Is First Party: No
Beta Identifier: 4564D79F-AE21-5979-BFE1-09F982F49EC5
Architecture: arm64
PID: 1337
Time Since Fork: 1008s
Event: hang
Duration: 1.07s
Steps: 11 (100ms sampling interval)
Hardware model: Mac14,3
Active cpus: 8
Memory size: 8 GB
HW page size: 16384
VM page size: 16384
Shared cache residency: 10.18% (478.09 MB / 4694.53 MB)
Time Since Boot: 10423s
Time Awake Since Boot: 5052s
Time Since Wake: 1288s
Fan speed: 1702 rpm
Total CPU Time: 7.847s (22.1G cycles, 41.0G instructions, 0.54c/i)
Advisory levels: Battery -> 2, User -> 2, ThermalPressure -> 0, Combined -> 2
Free disk space: 258.41 GB/460.43 GB, low space threshold 3072 MB
Vnodes Available: 61.79% (75024/121421)
Models: none
Preferred User Language: en-LV, lv-LV
Country Code: LV
Keyboards: ABC, Latvian
OS Cryptex File Extents: 1
Timeline format: stacks are sorted chronologically
Use -i and -heavy to re-report with count sorting
Heaviest stack for the main thread of the target process:
11 start + 6076 (dyld + 27544) [0x1818aeb98]
11 NSApplicationMain + 880 (AppKit + 17244) [0x185c2935c]
11 -[NSApplication run] + 480 (AppKit + 187492) [0x185c52c64]
11 -[NSApplication(NSEventRouting) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 688 (AppKit + 10327472) [0x1865fe5b0]
11 _DPSNextEvent + 684 (AppKit + 240308) [0x185c5fab4]
11 _BlockUntilNextEventMatchingListInModeWithFilter + 76 (HIToolbox + 2430084) [0x18d95a484]
73 hanz
Report Version: 60
Command: RUMlogNG
Team ID: 347RZE9T64
Is First Party: No
Architecture: arm64
PID: 1337
Event: hang
Duration: 1.07s
Active cpus: 8
Memory size: 8 GB
HW page size: 16384
VM page size: 16384
Fan speed: 1702 rpm
Models: none
Country Code: LV
