7610 tcp
hanz
7610 tcp
Unread post by hanz »
HelloTom,
Since i wenttrough my mac no more restarts, changed nothing.
Now i have an other question aboutbthe icom7610 icom server:
I do not know what i do wrong.
can you give me a hint.
Thisis the network status:
2:45:46 [Control] Common dealloc
12:50:01 ControlStream dealloc
12:50:01 [Control] My ip address:
12:50:01 [Control] Local address has wrong format!
12:50:01 [Control] Using 192.168.123.123 ...
12:50:01 [Control] socket started
12:50:01 [Control] 'I am here' sent
\and his is the set up:
the radio is communicating with the network, the NTP connection works.
73 hanz
Re: 7610 tcp
Check your privacy settings if RL is allowed to make local connections. If already On, toggle to Off and On again. Restart RL.
hanz
Re: 7610 tcp
Great great !!!!
works like a charm.
many thanks, hanz
This just happend when i started RL.
but still this hang problem, it is changed from hanging to have a exception, happened a few times last week.
Translated Report (Full Report Below)
Process: RUMlogNG [769]
Path: /Applications/RUMlogNG.app/Contents/MacOS/RUMlogNG
Identifier: de.dl2rum.RUMlogNG
Version: 5.19.5 (686)
App Item ID: 964454561
App External ID: 876007969
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2025-07-22 18:03:55.4671 +0300
OS Version: macOS 15.5 (24F74)
Report Version: 12
Anonymous UUID: A2092DE2-4C30-E766-3C8B-F7B107A0E1AC
Sleep/Wake UUID: 09A4CA31-BED5-495C-B340-4C3941AB6266
Time Awake Since Boot: 3900 seconds
Time Since Wake: 229 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000000000000001b
Exception Codes: 0x0000000000000001, 0x000000000000001b
Termination Reason: Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process: exc handler [769]
VM Region Info: 0x1b is not in any region. Bytes before following region: 4369530853
REGION TYPE START - END [ VSIZE] PRT/MAX SHRMOD REGION DETAIL
UNUSED SPACE AT START
__TEXT 10471c000-105070000 [ 9552K] r-x/r-x SM=COW /Applications/RUMlogNG.app/Contents/MacOS/RUMlogNG
Re: 7610 tcp
Please send the full crash report as file, not as text! Drag and drop the file out of the Console app.
hanz
Re: 7610 tcp
Hello Tom,
I renamed the IPS to TXT. IPS is not accepted in the post, invalid suffix.
thanks,
73 hanz
RUMlogNG_2025-07-22-182147_hanzs-Mac-mini.txt
(2.49 MiB) Downloaded 202 times
