Dr Tom,
Since a month Rumlog just hangs, beachball all te time .\I have to reboot the computer.
No idea why.
When i kill the rumlog proces and i want to start rumlog again it doesn't start up. Need to reboot the computer. (M2 mac mini)
I have the dump if you need it.
Radio's icom7300 and icom7610 with both connected it happens.
73 hanz YL3JD
Date/Time: 2025-07-14 14:35:13.852 +0300
End time: 2025-07-14 14:36:24.959 +0300
OS Version: macOS 15.5 (Build 24F74)
Architecture: arm64e
Report Version: 60
Incident Identifier: 39742AB5-2A11-436A-91C6-0EA7DEBD172C
Data Source: Stackshots
Shared Cache: D7397D7F-8DF9-3920-81A7-C0A144BE9C51 slid base address 0x1892dc000, slide 0x92dc000 (System Primary)
Shared Cache: CA9782E8-A954-3134-81A4-A7C6CB9CA2BD slid base address 0x185360000, slide 0x5360000 (DriverKit)
Shared Cache: 6E28F2B9-5B29-30C6-AF7C-47D23BF9EC34 slid base address 0x7ff80e2e8000, slide 0xe2e8000 (Rosetta)
Command: RUMlogNG
Path: /Applications/RUMlogNG.app/Contents/MacOS/RUMlogNG
Identifier: de.dl2rum.RUMlogNG
Version: 5.19.5 (686)
Team ID: 347RZE9T64
App Item ID: 964454561
App External ID: 876007969
Is First Party: No
Beta Identifier: 686B8403-EAE3-5BA4-867E-F6B4955BD25D
Architecture: arm64
Parent: launchd [1]
PID: 811
Time Since Fork: 26906s
Event: hang
Duration: 71.11s
Duration Sampled: 1.50s (process was unresponsive for 70 seconds before sampling)
Steps: 15 (100ms sampling interval)
hang
Re: hang
Thanks Tom,
I now unchecked CAT.
I thisnki ones installed a driver for communicating with QMX but i am not sure.
I try to look for a driver i used kextstat but did not see anything that looks like a syllabs driver or some thing like that.
I wait for my Wifi bridge so i can connect 7610 via wifi and do noyt need the cat. For now i check the behaviour with cat unchecked.
hanz
hanz
Re: hang
The only "thing" i could find under disabled software in the system profiler is this:
EG27766DY7 - com.silabs.driver.CP210xVCPDriver64:
Version: 3.0.0d1
Reason: No User Consent
Date Disabled: Unknown
I keep the CAT disabled and see if the hanging happens again.
Version: 3.0.0d1
