RUMlog and Spot
RUMlog and Spot
In RUMlog is a simple terminal for dx-cluster connection integrated. That's quite okay for most of the users. Others need a more comfortable dx-cluster application. Some users run Spot by K3NC (http://www.abrohamnealsoftware.com/ - US$ 15,-) Spot can act as a local server, so RUMlog can be connected to spot. This allows to use the advantages of both programs.
To activate the server open the Preferences in Spot under the Program tab:
Spot.tiff
Spot.tiff (1.3 MiB) Viewed 11091 times
Spot.tiff
Check the "Enable Server Port" box and enter a port, e.g. 7300. This port must not be used by other programs, even for cluster connection.
In RUMlog enter a new cluster connection:
RUMlog.tiff
RUMlog.tiff (126.34 KiB) Viewed 11091 times
RUMlog.tiff
The address is 'localhost' and the port must be the same you entered in spot, e.g. 7300.
Now you can select "Spot" in the cluster list in the RUMlog terminal window.
N1JM
Re: RUMlog and Spot
Unread post by N1JM »
I still get question marks in the mode column and I also noticed the frequency has a comma such as 7,100.00, if that has anything to do with the ???? problem. The author of Spot recognized there might be a problem or bug but has not got back to me in about a month.
John n1JM
Re: RUMlog and Spot
I was in contact with Neal, K3NC to inform him about this possible bug. A 'normal' dx-cluster sends spots with the frequency formatted like this: 14195.0 - No comma for the thousands and a period for the decimals. RUMlog expects this normal used format.
It seems to me, Spot exports frequencies in the format you have selected in your System Preferences in the "Language & Text section" under the "Formats" tab.
Try the following: Customize your system settings to remove the comma, separating the thousands. When the dx-spot is showing up correct, you should contact the author from the software you have payed for.
N1JM
Re: RUMlog and Spot
Thanks, That cured it. I changed the separator for thousands in numbers to none.
John N1JM
N1JM
Re: RUMlog and Spot
Another thing that is kind of minor, but Spot causes double spacing in the terminal window. I'll bounce this off of Neal, too.
John N1JM
K6LE
Re: RUMlog and Spot
Unread post by K6LE »
Yes, the double spacing is there in RUMlog or MLDX so it's an issue with what Spot outputs.
I don't notice it much because I usually minimize the Terminal window to the dock and only have the "DX Spots" window open and it isn't double spaced.
I have been using Spot to be my cluster server for RUMlog and MLDX together. That way I have clickable frequency setting no matter which logger currently has control of my rig. Works great!
Rick Prather
K6LE
Modesto, CA
2016 iMac 27" 5K
MacOS - HS
ea1het
Re: RUMlog and Spot
Unread post by ea1het »
Hi all,
i'm somehow new to Spot and RUMlog. What is the quick win to connect RUMlog to Spot instead to, let's say, VE7CC ??
Thanks in advance.
