I've just found an issue with the instructions I published for my Elecraft K2 variant - there is now an Issue 2 available on the Printables page.
Paul
M1CNK
Bluetooth LE CAT interface
If you would like to change the BT Interface name of your Adafruit Bluetooth LE UART Friend, here's how:
Use the Serial Tools app to connect to the serial side of the MAX3232 chip, referenced by VE3MM in an earlier post.
"AT+GAPDEVNAME' will show the current name.
To change the name (in my case 'NN7M KX2"):
"AT+GAPDEVNAME=NN7M KX2"
The background document with instructions is located here:
https://learn.adafruit.com/introducing- ... nd/ble-gap
Hope this helps,
Ryan NN7M
Hope this helps,
Ryan NN7M
I designed a 3d printed enclosure for the CAT interface. It is published on Printables. You can download the files here:
https://www.printables.com/model/119609 ... mlogng-rum
