CW with Icom IC-910H
PE2V
Unread post by PE2V »
I love RUMlogNG and use it a lot with my IC-7300. And it is also possible with RUMlogNG to send CW too (only in contest) with the internal Icom keyer.
But I own a IC-910H and with that TRX it is more complex. I also have a OptoCat MK2 interface with key output. Thats cool but..... For PTT it uses RTS and for CW it uses DTR (RS-232/USB port). Is it possible to use it this way in RUMlogNG? I can set PTT to RTS and works with digital modes but CW doesn't, because I can't set CW to DTR. Or am I missing a setting?
Thanks for any help!
73 Vincent
Re: CW with Icom IC-910H
RL doesn't have a build in CW keyer.
PE2V
DL2RUM wrote: ↑Mon 2. Dec 2024, 15:41 RL doesn't have a build in CW keyer.
I know but it can key the transceiver like it does with the 7300 over CAT. And I don’t know how it technically works, so please sorry when I talk nonsense probably.
Oh wait, I’m awake now. I have to set the IC910 to straight key, and therefore it does NOT use the internal keyer. So I need a keyer. And since RL does not have a build in keyer, it wil never work the way I thought. Clear.
