WSJTX and RumLOG2Go
do9jn
WSJTX and RumLOG2Go
Unread post by do9jn »
Hi :-)
Quick question. I am currently running my FTDX10 and my FT991a on a Linux system with FLRIG. From my MacBook, I then start WSJTX Remote and then log QSO on my MacBook. I would like not to always start up the MacBook and would rather use my iPad. Within RumlgNG2Go there is the possibility to log QSO via UDP. To which address does the UDP port (multicast?) listen to? And is the format used by WSJTX also supported on the iPad? Within WSJTX I have already tested 224.0.0.1 and the IP of the IP of the iPad, unfortunately unsuccessful....
73 de Joerg :-)
Re: WSJTX and RumLOG2Go
The UDP import function was introduced for QSOs logged with SDR-Control for iPad by Markus, DL8MRE. Unfortunately this protocol is not compatible with the WSJT-X UDP format.
See also the Help section on the iPad for more information.
