Not reading data from TS590 in latest version
s51mm
Unread post by s51mm »
Since the last update, RumlogNG is not reading data from TS590S, however sending commands to RIG works. For example: "follow trx", bandmap, reading CW is not working, but changing freq by clicking on bandmap, on cluster window, sending cw works fine. Is it possible to fix that?
73 David s51mm
s51mm
Re: Not reading data from TS590 in latest version
s51mm wrote: Sun 22. Oct 2023, 07:30 Since the last update, RumlogNG is not reading data from TS590S, however sending commands to RIG works. For example: "follow trx", bandmap, reading CW is not working, but changing freq by clicking on bandmap, on cluster window, sending cw works fine. Is it possible to fix that?
73 David s51mm
Update:
Problem is solved. Update to latest CP210x drivers solved the problem (yes, it is old Mac in shack). Everything is working as it should, life is good! :)
73, David
ea5xq
Unread post by ea5xq »
Hi, I am trying to sync RUMLOG with TS590SG, in order to tune with 590s and see the frequency in Khz field. I am using MacOS 11.7.10, should I install the CP210x drivers that you mention? (on the otherway around it works fine when controlling TRX from RUMLOG changing frecuency)
73's Juan, EA5XQ
http://www.ea5xq.net
ea5xq
Just installed v6.0.2 but not solved. I will review the manual just in case there is anything else missing in my installation
73's Juan, EA5XQ
