Crash due to exception when BPSK Narrow Low Selected
M0JEK
Unread post by M0JEK »
I am using RUMped 2.0 Beta 30, when in BPSK mode, if I select "Narrow Low" using the embedded waterfall display, I get the following exception pop up;
An exception of class OutOfBoundsException was not handled. The application must shut down.
This problem is repeatable on my system, and only occurs if I choose "Narrow Low". Using normal wide or "Narrow High" all is OK.
I am using cocoaModem 2.0 ver 0.79 and I am Mac OS X 10.4.11
There is no need to rush with a fix, as I am quite happy to use it as it is, however, I thought I'd just let you know what I saw. I do understand that RUMped is provided on a best efforts support, and I am using it at my own risk.
I have been using RUMped successfully on SSB contests.
Thank you for providing a wonderful and useful Macintosh software for free.
Capture of the popup
73 de André, M0JEK
Re: Crash due to exception when BPSK Narrow Low Selected
I can't duplicate the failure here. Please send a screen shot, where I can see the other PSK settings. Do you use the the cocoaModem Lite Interface?
M0JEK
Yes I am using the cocoaModem Lite setting. I have including a full screen shot. I hope it shows enough. The mode in use was BPSK63, and it was very busy. Might that have had an influence? I am running an old 1.67 GHz PowerBook G4 :-)
Full screen shot (scaled)
73 de André, M0JEK
Hmm, I 'm still unable to reproduce that. It happens only when selecting Narrow Low? All other possible selections are working fine? Can you try RTTY mode?
M0JEK
Have not had a chance yet ... will post once I do.
73 de André, M0JEK
