Doesn't remember columns settings
PA9CW
Unread post by PA9CW »
I use Rumlog for as long as I use Mac. I love it. It's a vy nice logbook. I had never problems, but now I have (maybe?) a simple problem.
I use a Macbook Pro 2022 and Rumlog 5.9.1
When I close and reopen Rumlog, the columns are reset to the default values. And not as I have set it myself. What can I do about it? On my iMac, that's not the case. And everything stays nicely in place. I hope you can help.
Thanks in advance for the reply. Tonnie - PA9CW
Re: Doesn't remember columns settings
Is it this specific table only or are other tables affected?
When it's the logbook table only try this:
  • Quit RUMlog
  • In the Terminal run following commands:
    • defaults delete de.dl2rum.RUMlogNG "NSTableView Columns v3 TableLog"
    • defaults delete de.dl2rum.RUMlogNG "NSTableView Supports v2 TableLog"
    • defaults delete de.dl2rum.RUMlogNG "NSTableView Sort Ordering v2 TableLog"
  • Restart your Mac
  • Start RUMlog and reorder the table.
PA9CW
I tried your tip. But it does not seem to solved the problem. All the colums go to default value again.
Sorry....
PA9CW
I tried your tip again, and now it seems to work. The last days I have opened and closed RUMLogNG maybe ten or twenty times. And the table settings are still okay. 👍
Thank for the help.
73 - Tonnie - PA9CW
