List of supported contests
va2cz
Unread post by va2cz »
Hi !
Is it possible to add the CWops OPEN in the supported contest list if you have the time to add it.
The contest is sept. 5th. Otherwise, no problem.
Thank you
Pierre, VA2CZ
theilerj
Unread post by theilerj »
Hi there,
It would be great if you could add the Swiss SwAC Contest. Here is the link to the website where the rules are also located (German English Italian) https://www.uska.ch/swac
73 HB9HBV
jweisskohl
Unread post by jweisskohl »
Can you please add support for the QCWA QSO Party?
Here is the link to the rules:
https://www.qcwa.org/2021-qso-party-rules.pdf
Thank you,
Jerry AC4BT
NN7M
Unread post by NN7M »
Could you add the SST to the list of contests? It’s on two times a week and gaining popularity.
Rules:
http://www.k1usn.com/sst_rules.html
Thank you,
Ryan NN7M
RafalLukawiecki
Unread post by RafalLukawiecki »
Could you, please, add the UKEICC contests? The next one is at the end of the month. There scoring rules are unique, and the region identifier needs to be exchanged.
Here is the rules page in German: https://www.ukeicc.com/DXcontestRules/rulesgerman.htm and in English: https://www.ukeicc.com/dx-contest-rules.php#
Thank you, very much! I hope to make this my first contest using your software. :)
PE2V
Unread post by PE2V »
I don't know if it is allowed to ask it in this topic,
I want to participate the DAC (Dutch Activity Contest, every Tuesday evening) on VHF / UHF / SHF and there for I need to collect: Call, Report, and LOCATOR. The points is the distance in KM's between the locators. Every unique locator gives 500 extra points.
But I checked a lot of existing contests in RL but could not find a contest that does this ;) Does anybody know which contest is calculating what I need for the DAC? At least the distance. 500 pnts per unique locator is not necessary.
Thanks for any suggestions!
Vy73 Vincent PE2V
Check the RSGB UKAC or the SSA Kvartalstest contests. Sounds similar to me.
PE2V
DL2RUM wrote: Tue 9. Nov 2021, 16:07 Check the RSGB UKAC or the SSA Kvartalstest contests. Sounds similar to me.
Thanks!! Checked but both require a serial number... it should be a contest without serial number..
Vy73 Vincent
Maybe the Global Mountain Activity Contest ? It's 2m only.
PE2V
DL2RUM wrote: Tue 9. Nov 2021, 16:20 Maybe the Global Mountain Activity Contest ? It's 2m only.
Yessss..... but you're right, for VHF only... UHF is not allowed :)
