Big Sur Update Broke RumlogNG for me
Hi -
As indicated in the title, Big Sur hosed my RumlogNG install. I did a complete reinstall to no avail. App crashes on launch. Any guidance of debugging I can do?
Chris
Chris
Re: Big Sur Update Broke RumlogNG for me
Thanks Tom. Searching for one, now.
Attached. Nothing stands out to me, but I do not know what I'm looking at
- Attachments
- RUMlogNG_2020-11-17-114203_.crash.txt
- (120.89 KiB) Downloaded 382 times
This version you use is not from the App store?
Try this and report: dl2rum.de/RUMlogNG/RUMlogNG_Test.zip
I tried the prod version from the store and your website and both have failed. The new test file fails with same error.
- Attachments
- RUMlogNG_2020-11-17-132846_.crash.txt
- (984 Bytes) Downloaded 387 times
Somewhat related, at least to Big Sur, I am crashing pretty consistently in RumLogNG when I am running WSJT-X, using DX Lab Suite Commander settings in WSJT-X v2.2.2, RumLogNG 5.0.2 (436). Crash occurs when I transmit the RR73 message. Crash log attached.
Hoop K9QJS
Hoop K9QJS
- Attachments
- RUMLOGNG_K9QJS_2020-11-17-1846.rtf
- (117.02 KiB) Downloaded 390 times
Post the second crashlog pse. Don't know what you've uploaded, but you should delete it. The first one was correct.
