I ran the ARRL January VHF contest this past weekend, and started out using my other PC with N1MM, but had some operator issues.
(aka this operator).
I tried exporting the N1MM contest file as and ADIF and importing it into the Contest in Rumlog, but it didn't pull over the
exchange ie My grid, the other stations grid.
I can import it directly into the logging program if I edit the exported N1MM file to add My gridsquare 6.
Is there a way to import it directly from one contest program to another ? or some other method - this would be great for emergency situations like computer failures etc.
Also, I guess there isn't yet a way for the program to talk to the rotor and move it to the station being worked in a contest?
Dana VE3DS
Toronto
Importing Contest Log from N1MM into RumlogNG
Re: Importing Contest Log from N1MM into RumlogNG
ADIF Import should work. I don't know the N1MM ADIF files, you should send me a sample for investigation.
