RumlogNG 4.0.3 CAT system does not work (IC-7610)
F5HFZ
Unread post by F5HFZ »
Hi
When I upgraded RumlogNG from 3.12.2 to 4.0.3, I lost the remote control of my icom 7610.
My configuration is :
Macbook Pro with HighSierra
Last version (5) of the SiLAbUSBdriver
Last firmware 1.20 of the IC-7610
I tried many configurations, reinstalled several time the driver Silab , changed the serial port in the preferences...etc... without success..
Using TimeMachine I was able to reinstall RumlogNG 3.12.2 and the CAT systems is working as usual.
I have now the two versions (3.12.2 and 4.0.3) on my hard disk and I confirm that - for my own configuration - I am not able to run the CAT system with the last version (I tried the two serial port, reset the system... etc...).
Any idea ?
TU
Nicolas, F5HFZ
Re: RumlogNG 4.0.3 CAT system does not work (IC-7610)
With this tool it is possible to find out the correct port: http://www.w7ay.net/site/Applications/I ... cover.html
Please note, the Auto discovery function in RUMlog will not work on High Sierra. Make sure this option is unset.
F5HFZ
Hi Tom
As I said in my post everytime I try with the two USB ports in the preferences and reset the cat system in the menu. Everything’s fine with the 3.12.2 version.
I doesn’t seem to be a driver problem.
Best 73
Nicolas,F5HFZ
F5HFZ
Hi Tom
I didn't read your post carefully early this morning, sorry.
So with "Auto discovery" unset, the new version of RumlogNG is now connecting the 7610 without trouble.
Thank a lot
Best 73
Nioclas
