Since the migration to RumLog NG, I have been facing some problems with the CAT Control of my TS480. I have the speed at 4800, 2 stop bit and parity set to none.
In Rumlog 5.3.13, although the 480 was not supported, I was using the TS570 definition, wich is very similar to the 480. When sniffing the serial port where the TS480 is attached, I found that when Rumlog starts send the AI1; command to the transceiver, wich according to the Kenwood documentation, sets the Auto Information to 1. After this the rig responds with an IF command such as this IF00021042840
<------------- Kenwood documentation ------------->
AI
Parameters:
P1
0: AI OFF
1: Only old AI format is ON
2: Only extended AI format is ON
3: Both formats are ON
When the extended AI format is selected, the transceiver
automatically sends the parameters.
When the old AI is ON and the IF parameters change, the
transceiver sends the IF command every 1.5 seconds.
When the transceiver is turned OFF, the AI parameter
becomes 0
With RumlogNG v3.6.2(176), usually no AI command is sent when I launch the software and the 480 is not showing the PC indication on the display. Sometimes (maybe 1 out of 10 times) when launching RumlogNG the command AI2; is sent and then the CAT works fine.
Here is the sequence when the cat is activated when RumlogNG is launched (RX is command send by RL, TX is the 480 Answer):
COM2-RX: AI2;[4] //Set AI to 2
COM2-RX: IF;[3] //Ask for the transceiver status
COM2-TX: IS 0000;[8] //The rig answers IFShift is 0
COM2-TX: ME000;[6] //No documentation on this command on the Kenwood pdf. Not always sent.
COM2-TX: PC100;[6] //The rig answers PWR is set to 100W. Not always sent.
COM2-TX: IF00021027220 002500000030000080;[38] //The rig answers with it status
Can you please take a look at this issue with the CAT control?. I'm on OSX10.10.5.
Thanks!
Juan J. Lamas - EA1NK.
