CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
EA3HOE
Re: 3.7?
Unread post by EA3HOE »
DL2RUM wrote:
Radio doesn't follow the band change in WSJT-X.
Does the radio follow RUMlog? Can you command the radio to QSY?
Yes, that works. For example, when i click on the bandplan or DX Spots the radio follows.
Funny how this board doesn't have the ability to delete your own account. :shock:
Re: 3.7?
I don't have a Kenwood available. I tested the TS-590S interface with my KX3, without any problems. The KX3 reacts like a Kenwood for the major CAT commands.
We should wait for other Kenwood users.
EA3HOE
Re: 3.7 CAT control WSJT-X and Kenwood TS-590S
Ok. No big issue for me at the moment. Just an inconvenience. BTW, i tried to run TCP2Serial you gave me a long time ago, but this crashes on start. Maybe something went corrupt. Maybe it just doesn't run on Sierra. Have you ever encountered that?
Ton.
Re: CAT Control issue WSJT-X->RUMlog using Kenwood TS590S
Yes, here it crashes since I use ipV6 local here.
EA3HOE
No IPV6 here, so it must be something else.
Maybe. In fact, getting the external ip address lets the app crash. Do you need an update?
EA3HOE
DL2RUM wrote:Maybe. In fact, getting the external ip address lets the app crash. Do you need an update?
If you have one, yes please. Maybe i can troubleshoot the issue i'm having.
EA3HOE
EA3HOE
Still crashes...
Process:               TCP2Serial [3676]
Path:                  /Applications/TCP2Serial.app/Contents/MacOS/TCP2Serial
Identifier:            de.dl2rum.TCP2Serial
Version:               1.1.4 (6)
Code Type:             X86-64 (Native)
Parent Process:        ??? [1]
Responsible:           TCP2Serial [3676]
User ID:               1829133891
Date/Time:             2017-08-30 19:05:05.591 +0200
OS Version:            Mac OS X 10.12.6 (16G29)
Report Version:        12
Anonymous UUID:        A8C78AFA-A78D-C0F6-E7F5-2E3AA66A857B
Time Awake Since Boot: 10000 seconds
System Integrity Protection: enabled
Crashed Thread:        6
Exception Type:        EXC_CRASH (SIGABRT)
Exception Codes:       0x0000000000000000, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Application Specific Information:
*** Terminating app due to uncaught exception 'NSInternalInconsistencyException', reason: 'Invalid parameter not satisfying: aString != nil'
terminating with uncaught exception of type NSException
abort() called
Application Specific Backtrace 1:
0   CoreFoundation                      0x00007fffa58042cb __exceptionPreprocess + 171
1   libobjc.A.dylib                     0x00007fffba61448d objc_exception_throw + 48
2   CoreFoundation                      0x00007fffa5809042 +[NSException raise:format:arguments:] + 98
3   Foundation                          0x00007fffa7251be0 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 195
4   AppKit                              0x00007fffa32a0dcd -[NSCell _objectValue:forString:errorDescription:] + 177
5   AppKit                              0x00007fffa32a0c72 -[NSCell setStringValue:] + 41
6   AppKit                              0x00007fffa334f91e -[NSControl setStringValue:] + 135
7   TCP2Serial                          0x000000010a2f04b7 TCP2Serial + 46263
8   Foundation                          0x00007fffa719d8ad __NSThread__start__ + 1243
9   libsystem_pthread.dylib             0x00007fffbb11393b _pthread_body + 180
10  libsystem_pthread.dylib             0x00007fffbb113887 _pthread_body + 0
11  libsystem_pthread.dylib             0x00007fffbb11308d thread_start + 13
Thread 0:: Dispatch queue: com.apple.main-thread
0   libsystem_kernel.dylib        	0x00007fffbb02134a mach_msg_trap + 10
1   libsystem_kernel.dylib        	0x00007fffbb020797 mach_msg + 55
2   com.apple.SkyLight            	0x00007fffb73073b7 SLSDisplayGetRefreshTiming + 212
3   com.apple.AppKit              	0x00007fffa393a3e9 +[NSDisplayTiming(NSDisplayTimingCreation) displayTimingForScreenNumber:] + 17
4   com.apple.AppKit              	0x00007fffa36a5941 __37+[NSDisplayCycle currentDisplayCycle]_block_invoke.31 + 467
5   com.apple.CoreFoundation      	0x00007fffa5799d37 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
6   com.apple.CoreFoundation      	0x00007fffa5799ca7 __CFRunLoopDoObservers + 391
7   com.apple.CoreFoundation      	0x00007fffa577a6d9 __CFRunLoopRun + 873
8   com.apple.CoreFoundation      	0x00007fffa577a114 CFRunLoopRunSpecific + 420
9   com.apple.HIToolbox           	0x00007fffa4cdaebc RunCurrentEventLoopInMode + 240
10  com.apple.HIToolbox           	0x00007fffa4cdabf9 ReceiveNextEventCommon + 184
11  com.apple.HIToolbox           	0x00007fffa4cdab26 _BlockUntilNextEventMatchingListInModeWithFilter + 71
12  com.apple.AppKit              	0x00007fffa3273a54 _DPSNextEvent + 1120
13  com.apple.AppKit              	0x00007fffa39ef7ee -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 2796
14  com.apple.AppKit              	0x00007fffa32683db -[NSApplication run] + 926
15  com.apple.AppKit              	0x00007fffa3232e0e NSApplicationMain + 1237
16  libdyld.dylib                 	0x00007fffbaefa235 start + 1
Thread 1:
0   libsystem_kernel.dylib        	0x00007fffbb02944e __workq_kernreturn + 10
1   libsystem_pthread.dylib       	0x00007fffbb113621 _pthread_wqthread + 1426
2   libsystem_pthread.dylib       	0x00007fffbb11307d start_wqthread + 13
Thread 2:
Thread 3:
1   libsystem_pthread.dylib       	0x00007fffbb11348e _pthread_wqthread + 1023
Thread 4:: Dispatch queue: NSCGSDisableUpdates
2   com.apple.SkyLight            	0x00007fffb72b4aaf _CGSReenableUpdateForConnectionSync + 99
3   com.apple.SkyLight            	0x00007fffb72c3dce CGSUpdateManager::enable_update(unsigned long long) + 532
4   libdispatch.dylib             	0x00007fffbaecd524 _dispatch_call_block_and_release + 12
5   libdispatch.dylib             	0x00007fffbaec48fc _dispatch_client_callout + 8
6   libdispatch.dylib             	0x00007fffbaeda9a0 _dispatch_queue_serial_drain + 896
7   libdispatch.dylib             	0x00007fffbaecd306 _dispatch_queue_invoke + 1046
8   libdispatch.dylib             	0x00007fffbaed3020 _dispatch_queue_override_invoke + 369
9   libdispatch.dylib             	0x00007fffbaec66b5 _dispatch_root_queue_drain + 476
10  libdispatch.dylib             	0x00007fffbaec648c _dispatch_worker_thread3 + 99
11  libsystem_pthread.dylib       	0x00007fffbb1135a2 _pthread_wqthread + 1299
12  libsystem_pthread.dylib       	0x00007fffbb11307d start_wqthread + 13
Thread 5:
Thread 6 Crashed:
0   libsystem_kernel.dylib        	0x00007fffbb028d42 __pthread_kill + 10
1   libsystem_pthread.dylib       	0x00007fffbb116457 pthread_kill + 90
2   libsystem_c.dylib             	0x00007fffbaf8e420 abort + 129
3   libc++abi.dylib               	0x00007fffb9ae194a abort_message + 266
4   libc++abi.dylib               	0x00007fffb9b06c2f default_terminate_handler() + 267
5   libobjc.A.dylib               	0x00007fffba6166fe _objc_terminate() + 103
6   libc++abi.dylib               	0x00007fffb9b03d49 std::__terminate(void (*)()) + 8
7   libc++abi.dylib               	0x00007fffb9b037be __cxa_throw + 121
8   libobjc.A.dylib               	0x00007fffba6145b6 objc_exception_throw + 345
9   com.apple.CoreFoundation      	0x00007fffa5809042 +[NSException raise:format:arguments:] + 98
10  com.apple.Foundation          	0x00007fffa7251be0 -[NSAssertionHandler handleFailureInMethod:object:file:lineNumber:description:] + 195
11  com.apple.AppKit              	0x00007fffa32a0dcd -[NSCell _objectValue:forString:errorDescription:] + 177
12  com.apple.AppKit              	0x00007fffa32a0c72 -[NSCell setStringValue:] + 41
13  com.apple.AppKit              	0x00007fffa334f91e -[NSControl setStringValue:] + 135
14  de.dl2rum.TCP2Serial          	0x000000010a2f04b7 0x10a2e5000 + 46263
15  com.apple.Foundation          	0x00007fffa719d8ad __NSThread__start__ + 1243
16  libsystem_pthread.dylib       	0x00007fffbb11393b _pthread_body + 180
17  libsystem_pthread.dylib       	0x00007fffbb113887 _pthread_start + 286
18  libsystem_pthread.dylib       	0x00007fffbb11308d thread_start + 13
Thread 7:: com.apple.NSURLConnectionLoader
2   com.apple.CoreFoundation      	0x00007fffa577b434 __CFRunLoopServiceMachPort + 212
3   com.apple.CoreFoundation      	0x00007fffa577a8c1 __CFRunLoopRun + 1361
4   com.apple.CoreFoundation      	0x00007fffa577a114 CFRunLoopRunSpecific + 420
5   com.apple.CFNetwork           	0x00007fffa48b7734 +[NSURLConnection(Loader) _resourceLoadLoop:] + 313
6   com.apple.Foundation          	0x00007fffa719d8ad __NSThread__start__ + 1243
7   libsystem_pthread.dylib       	0x00007fffbb11393b _pthread_body + 180
8   libsystem_pthread.dylib       	0x00007fffbb113887 _pthread_start + 286
9   libsystem_pthread.dylib       	0x00007fffbb11308d thread_start + 13
Thread 6 crashed with X86 Thread State (64-bit):
  rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x0000700006b1b3d8  rdx: 0x0000000000000000
  rdi: 0x0000000000009f03  rsi: 0x0000000000000006  rbp: 0x0000700006b1b400  rsp: 0x0000700006b1b3d8
   r8: 0x00007fffbafb7650   r9: 0x00007fffbaf79a50  r10: 0x0000000008000000  r11: 0x0000000000000206
  r12: 0x0000700006b1b560  r13: 0x0000000000000030  r14: 0x0000700006b1d000  r15: 0x0000000000000008
  rip: 0x00007fffbb028d42  rfl: 0x0000000000000206  cr2: 0x00007fffc3df0128
Logical CPU:     0
Error Code:      0x02000148
Trap Number:     133
Binary Images:
       0x10a2e5000 -        0x10a2fcffb +de.dl2rum.TCP2Serial (1.1.4 - 6) <5B442610-17B7-31D1-B814-8D55E088EE27> /Applications/TCP2Serial.app/Contents/MacOS/TCP2Serial
       0x10f8c9000 -        0x10fa6ffff  GLEngine (14.0.16) <08F2E804-13D2-3E80-9322-1A23A84A55F3> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
       0x10faae000 -        0x10fffdff7  com.apple.driver.AppleIntelBDWGraphicsGLDriver (10.25.17 - 10.2.5) <8633C1AB-7008-3B8B-8D6D-8E1DE49DD265> /System/Library/Extensions/AppleIntelBDWGraphicsGLDriver.bundle/Contents/MacOS/AppleIntelBDWGraphicsGLDriver
       0x110218000 -        0x110242fff  GLRendererFloat (14.0.16) <6B57F70A-EFAC-3DB2-B9BA-E55D05D44DB5> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
       0x11024c000 -        0x1102cbff7  com.apple.driver.AppleIntelBDWGraphicsMTLDriver (10.25.17 - 10.2.5) <20DB0471-534D-3570-9E5A-AB052CF54E68> /System/Library/Extensions/AppleIntelBDWGraphicsMTLDriver.bundle/Contents/MacOS/AppleIntelBDWGraphicsMTLDriver
       0x118ace000 -        0x118b0bdc7  dyld (433.5) <322C06B7-8878-311D-888C-C8FD2CA96FF3> /usr/lib/dyld
    0x7fffa224f000 -     0x7fffa224ffff  com.apple.Accelerate (1.11 - Accelerate 1.11) <916E360F-323C-3AE1-AB3D-D1F3B284AEE9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
    0x7fffa2250000 -     0x7fffa2267ffb  libCGInterfaces.dylib (331.5) <17109679-A284-3C72-AA60-DBA815D3062B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/Libraries/libCGInterfaces.dylib
    0x7fffa2268000 -     0x7fffa2781feb  com.apple.vImage (8.1 - ???) <B58A7937-BEE2-38FE-87F4-5D5F40D31DC9> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
    0x7fffa2782000 -     0x7fffa28f3ff3  libBLAS.dylib (1185.50.4) <4087FFE0-627E-3623-96B4-F0A9A1991E09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
    0x7fffa28f4000 -     0x7fffa2908ffb  libBNNS.dylib (15) <254698C7-7D36-3FFF-864E-ADEEEE543076> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBNNS.dylib
    0x7fffa2909000 -     0x7fffa2cfffef  libLAPACK.dylib (1185.50.4) <C35FFB2F-A0E6-3903-8A3C-113A74BCBCA2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
    0x7fffa2d00000 -     0x7fffa2d16fff  libLinearAlgebra.dylib (1185.50.4) <345CAACF-7263-36EF-B69B-793EA8B390AF> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
    0x7fffa2d17000 -     0x7fffa2d1dfff  libQuadrature.dylib (3) <EF56C8E6-DE22-3C69-B543-A8648F335FDD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libQuadrature.dylib
    0x7fffa2d1e000 -     0x7fffa2d32ff7  libSparseBLAS.dylib (1185.50.4) <67BA432E-FB59-3C78-A8BE-ED4274CBC359> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libSparseBLAS.dylib
    0x7fffa2d33000 -     0x7fffa2ebafe7  libvDSP.dylib (600.60.1) <4155F45B-41CD-3782-AE8F-7AE740FD83C3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
    0x7fffa2ebb000 -     0x7fffa2f6dfff  libvMisc.dylib (600.60.1) <E18365D7-DCC4-3304-A8D1-395E656D7B99> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
    0x7fffa2f6e000 -     0x7fffa2f6efff  com.apple.Accelerate.vecLib (3.11 - vecLib 3.11) <7C5733E7-0568-3E7D-AF61-160F19FED544> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
    0x7fffa322d000 -     0x7fffa4006ff3  com.apple.AppKit (6.9 - 1504.83.101) <AE51ACB3-D501-3F91-B369-3D3711F24D0A> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7fffa4018000 -     0x7fffa4018fff  com.apple.ApplicationServices (48 - 48) <DA687F9A-7B2D-342B-8796-16E45344F853> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
    0x7fffa4019000 -     0x7fffa4087ff7  com.apple.ApplicationServices.ATS (377 - 422.2) <A31D17BE-F747-39FB-9A84-5F2F8891204C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
    0x7fffa4121000 -     0x7fffa4250ff7  libFontParser.dylib (194.12) <73C3946D-EF92-3AC1-89C3-0E75B2A85325> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
    0x7fffa4251000 -     0x7fffa429bfff  libFontRegistry.dylib (196.4) <EA96AE47-3369-3DEA-BB82-98348ADBD85B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
    0x7fffa42f8000 -     0x7fffa432bfff  libTrueTypeScaler.dylib (194.12) <8944A23A-EE36-3657-9B4F-933231C8FDEC> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
    0x7fffa4398000 -     0x7fffa4442ff7  com.apple.ColorSync (4.12.0 - 502.2) <ACA4001E-A0E3-33F6-9CD6-EEC2AA15E322> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
    0x7fffa4443000 -     0x7fffa4494fff  com.apple.HIServices (1.22 - 593) <045870A9-1D92-3FEF-8722-671E99A35E71> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
    0x7fffa4495000 -     0x7fffa44a4ff3  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2CBE7F61-2056-3F96-99A1-0D527796AFA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
    0x7fffa44a5000 -     0x7fffa44f2fff  com.apple.print.framework.PrintCore (12 - 491) <5027FD58-F0EE-33E4-8577-934CA06CD2AF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
    0x7fffa44f3000 -     0x7fffa452efff  com.apple.QD (3.12 - 313) <B339C41D-8CDF-3342-8414-F9717DCCADD4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
    0x7fffa452f000 -     0x7fffa453afff  com.apple.speech.synthesis.framework (6.6.2 - 6.6.2) <7853EFF4-62B9-394E-B7B8-41A645656820> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
    0x7fffa453b000 -     0x7fffa4747ff7  com.apple.audio.toolbox.AudioToolbox (1.14 - 1.14) <01518CAB-7DAD-3F09-83F8-B9FE0ABE998F> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
    0x7fffa4748000 -     0x7fffa4748fff  com.apple.audio.units.AudioUnit (1.14 - 1.14) <B92868F8-2F15-32C0-A5BE-4ABA546B8BE1> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
    0x7fffa48b1000 -     0x7fffa4c8bfff  com.apple.CFNetwork (811.5.4 - 811.5.4) <46B1227B-F38C-3F8E-B0B5-5D9861ABF36B> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
    0x7fffa4caa000 -     0x7fffa4fb3fff  com.apple.HIToolbox (2.1.1 - 857.8) <5367366E-747E-32CF-8E76-93CD8E7424C7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
    0x7fffa4fbe000 -     0x7fffa5055ff3  com.apple.ink.framework (10.9 - 219) <1BD40B45-FD33-3177-A935-565EE5FC79D7> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
    0x7fffa5076000 -     0x7fffa507cff7  com.apple.speech.recognition.framework (6.0.1 - 6.0.1) <082895DC-3AC7-3DEF-ADCA-5B018C19C9D3> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
    0x7fffa52a7000 -     0x7fffa5334fff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <78767F88-91D4-31CE-AAC6-1F9407F479BB> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
    0x7fffa5335000 -     0x7fffa5348fff  com.apple.CoreBluetooth (1.0 - 1) <BCB78777-76F0-3CC1-8443-9E61AEF7EF63> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
    0x7fffa5349000 -     0x7fffa5644fff  com.apple.CoreData (120 - 754.2) <4C9CAB2C-60D4-3694-A0A0-5B04B14BD14E> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
    0x7fffa5645000 -     0x7fffa56f2ff7  com.apple.CoreDisplay (1.0 - 1) <53D1EAFE-23A4-398D-BF52-E4299E670DB6> /System/Library/Frameworks/CoreDisplay.framework/Versions/A/CoreDisplay
    0x7fffa56f3000 -     0x7fffa5b8cff7  com.apple.CoreFoundation (6.9 - 1349.8) <09ED473E-5DE8-307F-B55C-16F6419236D5> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7fffa5b8d000 -     0x7fffa620ffff  com.apple.CoreGraphics (2.0 - 1070.22) <FAB476BB-B5CD-3936-8AFC-41229DBDF0E8> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
    0x7fffa6210000 -     0x7fffa6453ffb  com.apple.CoreImage (12.4.0 - 451.4.9) <BE4303C9-C9D9-361D-AC94-DBE40EB6700E> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
    0x7fffa65b8000 -     0x7fffa65b8fff  com.apple.CoreServices (775.19 - 775.19) <7255917D-EFBB-3BE2-A8FD-DAD631BC0949> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
    0x7fffa65b9000 -     0x7fffa660afff  com.apple.AE (712.5 - 712.5) <61F2AE2C-E04E-3FDF-9E88-201325136C83> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
    0x7fffa660b000 -     0x7fffa68e6ff7  com.apple.CoreServices.CarbonCore (1159.6 - 1159.6) <08AC074C-965B-3EDF-8E45-0707C8DE9EAD> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
    0x7fffa68e7000 -     0x7fffa691afff  com.apple.DictionaryServices (1.2 - 274) <D23866E2-F7C8-3984-A9D4-96552CCDE573> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
    0x7fffa691b000 -     0x7fffa6923ff3  com.apple.CoreServices.FSEvents (1230.50.1 - 1230.50.1) <2AD1B0E5-7214-37C4-8D11-A27C9CAC0F74> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
    0x7fffa6924000 -     0x7fffa6a90ff7  com.apple.LaunchServices (775.19 - 775.19) <B75A0C49-E376-358C-81EE-6EFB0F605801> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
    0x7fffa6a91000 -     0x7fffa6b41ffb  com.apple.Metadata (10.7.0 - 1075.40) <B2FFCC10-5A9E-396B-B495-3D6C867669EE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
    0x7fffa6b42000 -     0x7fffa6ba1fff  com.apple.CoreServices.OSServices (775.19 - 775.19) <4140569A-1848-3765-A52B-BB61C35CF88F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
    0x7fffa6ba2000 -     0x7fffa6c12fff  com.apple.SearchKit (1.4.0 - 1.4.0) <7A6DDA2B-03F1-3137-BA9E-1CC211973E26> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
    0x7fffa6c13000 -     0x7fffa6c58ff7  com.apple.coreservices.SharedFileList (38 - 38) <DA096678-93AB-3291-BDE2-482F1D544589> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.framework/Versions/A/SharedFileList
    0x7fffa6ce1000 -     0x7fffa6e2effb  com.apple.CoreText (352.0 - 544.15) <BF0EE575-BB7E-3BF9-9029-232B4ADC24E4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
    0x7fffa6e2f000 -     0x7fffa6e64ff3  com.apple.CoreVideo (1.8 - 235.3) <AC11D5FB-C77B-34F5-B942-F698E84C229F> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
    0x7fffa6e65000 -     0x7fffa6ed6ffb  com.apple.framework.CoreWLAN (11.0 - 1200.31) <E47C0568-E37B-3052-9E77-F0F371DCDE7F> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
    0x7fffa6fd4000 -     0x7fffa6fd9fff  com.apple.DiskArbitration (2.7 - 2.7) <70F56042-EF04-3BAF-9E04-90F423FB2BCC> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
    0x7fffa716b000 -     0x7fffa7511fff  com.apple.Foundation (6.9 - 1349.91) <A37CB4EC-0730-3DD6-9358-60491BF40EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7fffa753d000 -     0x7fffa756eff7  com.apple.GSS (4.0 - 2.0) <6FADED0B-0425-3567-A75A-040C5A4638EB> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
    0x7fffa762e000 -     0x7fffa76d1fff  com.apple.Bluetooth (5.0.5 - 5.0.5f1) <913B97A6-9E18-3F15-992D-D522AA22EDE9> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
    0x7fffa76d2000 -     0x7fffa7768ff7  com.apple.framework.IOKit (2.0.2 - 1324.60.3) <7CE4C98B-107C-3AAA-B49A-F2ACFCBBF526> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
    0x7fffa7769000 -     0x7fffa776fffb  com.apple.IOSurface (159.9 - 159.9) <08F1A246-1367-32EC-B3CE-724379409729> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
    0x7fffa77c2000 -     0x7fffa7922fef  com.apple.ImageIO.framework (3.3.0 - 1599.12) <E54ADBF0-6001-3DEB-AEB0-3F857A781E06> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
    0x7fffa7923000 -     0x7fffa7927fff  libGIF.dylib (1599.12) <A0836C44-9566-32A3-ACCF-82A5BAF2E521> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
    0x7fffa7928000 -     0x7fffa7a18ff7  libJP2.dylib (1599.12) <0DB4F152-B36D-365C-97B1-34F1C114982B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
    0x7fffa7a19000 -     0x7fffa7a3cffb  libJPEG.dylib (1599.12) <2F66BA16-D569-35AD-A4BB-7A1909F1BF11> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
    0x7fffa7a3d000 -     0x7fffa7a64ff7  libPng.dylib (1599.12) <A068239E-7DB3-33AD-BEA9-499D8DEF771B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
    0x7fffa7a65000 -     0x7fffa7a67ff3  libRadiance.dylib (1599.12) <D26D6FC9-1175-38AB-ACAA-0CA073FD3978> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
    0x7fffa7a68000 -     0x7fffa7ab6ffb  libTIFF.dylib (1599.12) <5D161E6A-D279-37A0-9F5F-A71A4C13BB09> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
    0x7fffa881f000 -     0x7fffa8838ff7  com.apple.Kerberos (3.0 - 1) <B9D242EB-E325-3A21-9812-C77CBBFB0D51> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
    0x7fffa9018000 -     0x7fffa9073fff  com.apple.Metal (87.18 - 87.18) <E3618B54-C728-34CA-9E8A-9BD33A295D31> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
    0x7fffa995c000 -     0x7fffa9964fff  com.apple.NetFS (6.0 - 4.0) <14A24D00-5673-330A-959D-87F72040DEFF> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
    0x7fffa9b3b000 -     0x7fffa9b43ff7  libcldcpuengine.dylib (2.8.5) <81563526-886E-37E4-BF85-4A6D75F93C65> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
    0x7fffa9b44000 -     0x7fffa9b92ff3  com.apple.opencl (2.8.6 - 2.8.6) <E78463D3-73B6-3002-BD71-9CC1D6722968> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
    0x7fffa9b93000 -     0x7fffa9bacffb  com.apple.CFOpenDirectory (10.12 - 194) <A64E9A01-3F6E-36EA-9C10-88C564A68C9D> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
    0x7fffa9bad000 -     0x7fffa9bb8ff7  com.apple.OpenDirectory (10.12 - 194) <4298FFD0-B1A7-3064-AF5B-708B3FA38671> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
    0x7fffa9bb9000 -     0x7fffa9bbbfff  libCVMSPluginSupport.dylib (14.0.16) <9E12EB67-6630-39A0-AB93-77405F5EC2A7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
    0x7fffa9bbc000 -     0x7fffa9bbfff7  libCoreFSCache.dylib (156.3) <687C4CC3-6537-344B-8BE1-5234C8CB2864> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
    0x7fffa9bc0000 -     0x7fffa9bc4fff  libCoreVMClient.dylib (156.3) <E7AEFCBE-B6BF-3C7C-9A4E-E78CB04DB794> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
    0x7fffa9bc5000 -     0x7fffa9bceff7  libGFXShared.dylib (14.0.16) <D10C7A01-8A11-3A42-A9FA-C411AE453B27> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
    0x7fffa9bcf000 -     0x7fffa9bdafff  libGL.dylib (14.0.16) <0801F3B9-A525-32BB-9BC0-478947CE21D9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
    0x7fffa9bdb000 -     0x7fffa9c17ff7  libGLImage.dylib (14.0.16) <FE39C57B-056C-3CBF-B653-A8F2005631C1> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
    0x7fffa9c18000 -     0x7fffa9d8eff3  libGLProgrammability.dylib (14.0.16) <A95F26AD-D496-3581-A310-5131F61CFB4A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
    0x7fffa9d8f000 -     0x7fffa9dd0ff7  libGLU.dylib (14.0.16) <B285EAD6-B3AA-3753-BB85-75864BD6E76C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
    0x7fffaa738000 -     0x7fffaa746fff  com.apple.opengl (14.0.16 - 14.0.16) <167C9883-A79E-3B7F-AFED-8CD6683B291D> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
    0x7fffab298000 -     0x7fffab498fff  com.apple.QuartzCore (1.11 - 453.39.4) <A45AFBC4-87D4-3533-A0AC-1D6629C77984> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
    0x7fffab9ff000 -     0x7fffabd01ff7  com.apple.security (7.0 - 57740.60.18) <005E8C96-40B6-35E3-B58B-888A5F5957C2> /System/Library/Frameworks/Security.framework/Versions/A/Security
    0x7fffabd02000 -     0x7fffabd77fff  com.apple.securityfoundation (6.0 - 55132.50.7) <15C53957-A9DE-31AE-A192-949244F47CD7> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
    0x7fffabda2000 -     0x7fffabda5ff3  com.apple.xpc.ServiceManagement (1.0 - 1) <BE0F9708-0B55-3E78-A15E-C287B8ED13BA> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
    0x7fffac12c000 -     0x7fffac19bff7  com.apple.SystemConfiguration (1.14 - 1.14) <3FFD3930-B307-3E31-9FA6-12221EB0F969> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
    0x7fffaea1c000 -     0x7fffaea3effb  com.apple.framework.Apple80211 (12.0 - 1200.47) <C3033EEE-771A-3664-BBDD-BE1F6D075FC7> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
    0x7fffaea3f000 -     0x7fffaea4efeb  com.apple.AppleFSCompression (88.50.3 - 1.0) <478E8BFF-8BA2-375E-BE02-BA27F115C15A> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
    0x7fffaeb3c000 -     0x7fffaebc797f  com.apple.AppleJPEG (1.0 - 1) <B9E9570D-04A4-34E4-B756-D200043B25B8> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
    0x7fffaeffa000 -     0x7fffaf078ff7  com.apple.backup.framework (1.8.5 - 1.8.5) <CC679891-E8F5-3166-8EB6-AEA06954A52D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
    0x7fffafd03000 -     0x7fffafd2aff3  com.apple.ChunkingLibrary (173 - 173) <FC2165F9-FC93-39C0-8323-C2F43A5E00A3> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
    0x7fffb064f000 -     0x7fffb0658ffb  com.apple.CommonAuth (4.0 - 2.0) <216950CB-269F-3476-BA17-D6363AC49FBC> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
    0x7fffb0da1000 -     0x7fffb0db1fff  com.apple.CoreEmoji (1.0 - 40.3.3) <E9A28301-2D79-3A97-A046-028258A6ABE5> /System/Library/PrivateFrameworks/CoreEmoji.framework/Versions/A/CoreEmoji
    0x7fffb10ec000 -     0x7fffb111cff3  com.apple.CoreServicesInternal (276.2 - 276.2) <05EB7D45-DD4C-3A0F-AC63-A0C2A68E6481> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
    0x7fffb13ad000 -     0x7fffb143cff7  com.apple.CoreSymbolication (62046) <7839CD8E-011D-3567-88DE-3D472C661136> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
    0x7fffb143d000 -     0x7fffb157cfe7  com.apple.coreui (2.1 - 431.3) <2E8FEC10-FC5B-3782-92DA-A85C24B7BF7C> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
    0x7fffb157d000 -     0x7fffb164dff3  com.apple.CoreUtils (5.1 - 510.31) <E68BB8ED-8874-36EC-A7C5-1017C0E727CB> /System/Library/PrivateFrameworks/CoreUtils.framework/Versions/A/CoreUtils
    0x7fffb169d000 -     0x7fffb1702ff3  com.apple.framework.CoreWiFi (12.0 - 1200.31) <DF0972EF-F817-3FD3-8C00-2D57B8738D8C> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
    0x7fffb1703000 -     0x7fffb1711ff7  com.apple.CrashReporterSupport (10.12 - 827) <802A9B81-E349-348B-90AB-10E40B654250> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
    0x7fffb1783000 -     0x7fffb178dffb  com.apple.framework.DFRFoundation (1.0 - 104.25) <7CFF896C-EF22-3941-BB3D-F3615CE4C908> /System/Library/PrivateFrameworks/DFRFoundation.framework/Versions/A/DFRFoundation
    0x7fffb178e000 -     0x7fffb1792ff3  com.apple.DSExternalDisplay (3.1 - 380) <4B5E3FF0-E8C3-38CC-BF72-418C928956AB> /System/Library/PrivateFrameworks/DSExternalDisplay.framework/Versions/A/DSExternalDisplay
    0x7fffb17c8000 -     0x7fffb183dffb  com.apple.datadetectorscore (7.0 - 539.1) <74595F6C-8283-3C73-9F56-C6FA957F8B94> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
    0x7fffb1879000 -     0x7fffb18b8fff  com.apple.DebugSymbols (137 - 137) <58A70B66-2628-3CFE-B103-2200D95FC5F7> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
    0x7fffb18b9000 -     0x7fffb19cafff  com.apple.desktopservices (1.11.5 - 1.11.5) <46A9D4F3-1EF8-373C-98A4-AD48D285E484> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
    0x7fffb1cb2000 -     0x7fffb20e3ff7  com.apple.vision.FaceCore (3.3.2 - 3.3.2) <9391D5A3-738C-3136-9D07-518CB43DBADA> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
    0x7fffb343a000 -     0x7fffb343afff  libmetal_timestamp.dylib (600.0.49.9) <E5EED927-1671-3390-BCBB-D76201D63C73> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
    0x7fffb3447000 -     0x7fffb3452ff3  libGPUSupportMercury.dylib (14.0.16) <7EE3DA75-2F9D-3C6D-AECD-F73EA47BE81B> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupportMercury.dylib
    0x7fffb370b000 -     0x7fffb3727fff  com.apple.GenerationalStorage (2.0 - 267.1) <3DE1C580-D089-362D-8582-8DE68A3C5F13> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
    0x7fffb3e38000 -     0x7fffb3eaeff3  com.apple.Heimdal (4.0 - 2.0) <8F9C9041-66D5-36C9-8A4C-1658035C311D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
    0x7fffb44c9000 -     0x7fffb44d0ffb  com.apple.IOAccelerator (311.14 - 311.14) <278124AF-02DC-3785-9FA9-14EDB8E5FD56> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
    0x7fffb44d2000 -     0x7fffb44e6ff7  com.apple.IOPresentment (1.0 - 29.10) <30DF04EE-10E2-353F-845F-A97B87DF3207> /System/Library/PrivateFrameworks/IOPresentment.framework/Versions/A/IOPresentment
    0x7fffb44e7000 -     0x7fffb4509fff  com.apple.IconServices (74.4 - 74.4) <218DDD05-35F4-3833-B98D-471ED0EBC031> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
    0x7fffb45f0000 -     0x7fffb47a7fff  com.apple.LanguageModeling (1.0 - 123.2.5) <A8CA965F-0399-310D-91C3-B93DDDE9A442> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
    0x7fffb50c8000 -     0x7fffb5141ff7  com.apple.MetalPerformanceShaders.MetalPerformanceShaders (1.0 - 1) <C323FC94-FFA5-3EE6-B2AC-7E61EA92F304> /System/Library/PrivateFrameworks/MetalPerformanceShaders.framework/Versions/A/MetalPerformanceShaders
    0x7fffb52bc000 -     0x7fffb52e4ff7  com.apple.MultitouchSupport.framework (368.16 - 368.16) <9E602B4A-22CD-3CF3-B284-78D5123C9AE8> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
    0x7fffb5396000 -     0x7fffb53a1fff  com.apple.NetAuth (6.2 - 6.2) <97F487D6-8089-31A8-B68C-6C1EAC6ED1B5> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
    0x7fffb5c79000 -     0x7fffb5cbaff3  com.apple.PerformanceAnalysis (1.148.3 - 148.3) <4E468BC7-F863-3674-909D-417231EB8C28> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
    0x7fffb63a2000 -     0x7fffb63bcfff  com.apple.ProtocolBuffer (1 - 249.1) <A1F1B0F3-078F-378F-A9A9-0DEEA70E816A> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
    0x7fffb63d5000 -     0x7fffb63f8ff3  com.apple.RemoteViewServices (2.0 - 124) <6B967FDA-6591-302C-BA0A-76C4856E584E> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
    0x7fffb7154000 -     0x7fffb71e1fff  com.apple.Sharing (696.2.67 - 696.2.67) <F681EE28-153F-3216-97A6-6F5E4148AB2E> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
    0x7fffb7202000 -     0x7fffb7468feb  com.apple.SkyLight (1.600.0 - 170.3) <38AC05EF-3A9E-3E3E-9849-04E0223DF7B9> /System/Library/PrivateFrameworks/SkyLight.framework/Versions/A/SkyLight
    0x7fffb7647000 -     0x7fffb7653ff7  com.apple.SpeechRecognitionCore (3.3.2 - 3.3.2) <684BD1EA-8268-331C-A5A9-080EB375C658> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecognitionCore
    0x7fffb7d3f000 -     0x7fffb7db3fdf  com.apple.Symbolication (62048.1) <1A30ED19-7532-3F46-9DD3-9879A973D0CF> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
    0x7fffb81f2000 -     0x7fffb81f8ff7  com.apple.TCC (1.0 - 1) <911B534B-4AC7-34E4-935E-E42ECD008CBC> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
    0x7fffb8284000 -     0x7fffb834aff7  com.apple.TextureIO (2.8 - 2.8) <3D61E533-4156-3B21-B7ED-CB823E680DFC> /System/Library/PrivateFrameworks/TextureIO.framework/Versions/A/TextureIO
    0x7fffb83be000 -     0x7fffb83bffff  com.apple.TrustEvaluationAgent (2.0 - 28.50.1) <EBE65DD5-1732-3747-8C6C-7BECEBF089A4> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
    0x7fffb83c0000 -     0x7fffb8550ff3  com.apple.UIFoundation (1.0 - 490.7) <2A3063FE-1790-3510-8A0E-AEC581D42B7E> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
    0x7fffb9601000 -     0x7fffb9603ffb  com.apple.loginsupport (1.0 - 1) <F3140B97-12C3-35A7-9D3D-43DA2D13C113> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
    0x7fffb9658000 -     0x7fffb9673ff7  libCRFSuite.dylib (34) <F78B7F5F-0B4F-35C6-AA2F-84EE9CB22137> /usr/lib/libCRFSuite.dylib
    0x7fffb9674000 -     0x7fffb967ffff  libChineseTokenizer.dylib (21) <0886E908-A825-36AF-B94B-2361FD8BC2A1> /usr/lib/libChineseTokenizer.dylib
    0x7fffb9711000 -     0x7fffb9712ff3  libDiagnosticMessagesClient.dylib (102) <84A04D24-0E60-3810-A8C0-90A65E2DF61A> /usr/lib/libDiagnosticMessagesClient.dylib
    0x7fffb9713000 -     0x7fffb9926fff  libFosl_dynamic.dylib (16.39) <E22A4243-D148-3C74-BA15-2D906A3D1F9E> /usr/lib/libFosl_dynamic.dylib
    0x7fffb994a000 -     0x7fffb994afff  libOpenScriptingUtil.dylib (172) <90743888-C1E8-34E3-924E-1A754B2B63B9> /usr/lib/libOpenScriptingUtil.dylib
    0x7fffb994b000 -     0x7fffb994fffb  libScreenReader.dylib (477.40.6) <CBE6420C-EF60-3ACD-A0B6-7CBE936BA3B8> /usr/lib/libScreenReader.dylib
    0x7fffb9950000 -     0x7fffb9951ffb  libSystem.B.dylib (1238.60.2) <F18AC1E7-C6F1-34B1-8069-BE571B3231D4> /usr/lib/libSystem.B.dylib
    0x7fffb99bd000 -     0x7fffb99e8ff3  libarchive.2.dylib (41.70.1) <A3FA7D6E-3D68-3524-8B48-EB2ECA44B13B> /usr/lib/libarchive.2.dylib
    0x7fffb99e9000 -     0x7fffb9a65fc7  libate.dylib (1.12.13) <D0767875-D02E-3377-84D8-5F174C27BEA9> /usr/lib/libate.dylib
    0x7fffb9a69000 -     0x7fffb9a69ff3  libauto.dylib (187) <34388D0B-C539-3C1B-9408-2BC152162E43> /usr/lib/libauto.dylib
    0x7fffb9a6a000 -     0x7fffb9a7aff3  libbsm.0.dylib (34) <20084796-B04D-3B35-A003-EA11459557A9> /usr/lib/libbsm.0.dylib
    0x7fffb9a7b000 -     0x7fffb9a89ff7  libbz2.1.0.dylib (38) <ADFA329A-DCE7-356D-8F09-A3168DFC6610> /usr/lib/libbz2.1.0.dylib
    0x7fffb9a8a000 -     0x7fffb9ae0ff7  libc++.1.dylib (307.5) <0B43BB5D-E6EB-3464-8DE9-B41AC8ED9D1C> /usr/lib/libc++.1.dylib
    0x7fffb9ae1000 -     0x7fffb9b0aff7  libc++abi.dylib (307.4) <BC271AD3-831B-362A-9DA7-E8C51F285FE4> /usr/lib/libc++abi.dylib
    0x7fffb9b0b000 -     0x7fffb9b1bffb  libcmph.dylib (6) <2B5D405E-2D0B-3320-ABD6-622934C86ABE> /usr/lib/libcmph.dylib
    0x7fffb9b1c000 -     0x7fffb9b32fcf  libcompression.dylib (39) <F2726F95-F54E-3B21-BCB5-F7151DEFDC2F> /usr/lib/libcompression.dylib
    0x7fffb9b33000 -     0x7fffb9b33ff7  libcoretls.dylib (121.50.4) <64B1001E-10F6-3542-A3B2-C4B49F51817F> /usr/lib/libcoretls.dylib
    0x7fffb9b34000 -     0x7fffb9b35ff3  libcoretls_cfhelpers.dylib (121.50.4) <1A10303E-5EB0-3C7C-9165-021FCDFD934D> /usr/lib/libcoretls_cfhelpers.dylib
    0x7fffb9bef000 -     0x7fffb9cd4ff7  libcrypto.0.9.8.dylib (64.50.6) <D34E16A7-990A-37A9-933A-DFAA46554EAA> /usr/lib/libcrypto.0.9.8.dylib
    0x7fffb9e72000 -     0x7fffb9ec5ff7  libcups.2.dylib (450) <9950BFCB-7882-33C9-9ECF-CE66773C5657> /usr/lib/libcups.2.dylib
    0x7fffb9f42000 -     0x7fffb9f42fff  libenergytrace.dylib (15) <A1B040A2-7977-3097-9ADF-34FF181EB970> /usr/lib/libenergytrace.dylib
    0x7fffb9f52000 -     0x7fffb9f57ff7  libheimdal-asn1.dylib (498.50.8) <A40E3196-235E-34CE-AD9A-8D1AFC5DE004> /usr/lib/libheimdal-asn1.dylib
    0x7fffb9f58000 -     0x7fffba04aff7  libiconv.2.dylib (50) <42125B35-81D7-3FC4-9475-A26DBE10884D> /usr/lib/libiconv.2.dylib
    0x7fffba04b000 -     0x7fffba270ffb  libicucore.A.dylib (57166.0.1) <CCD2ED24-3071-383B-925D-8D763BB12A6F> /usr/lib/libicucore.A.dylib
    0x7fffba276000 -     0x7fffba277fff  liblangid.dylib (126) <2085E7A7-9A34-3735-87F4-F174EF8EABF0> /usr/lib/liblangid.dylib
    0x7fffba278000 -     0x7fffba291ffb  liblzma.5.dylib (10) <44BD0279-99DD-36B5-8A6E-C11432E2098D> /usr/lib/liblzma.5.dylib
    0x7fffba292000 -     0x7fffba2a8ff7  libmarisa.dylib (5) <9030D214-5D0F-30CB-AC03-902C63909362> /usr/lib/libmarisa.dylib
    0x7fffba2a9000 -     0x7fffba551ff7  libmecabra.dylib (744.8) <D429FCC9-42A4-38B3-8784-44024BC859EF> /usr/lib/libmecabra.dylib
    0x7fffba584000 -     0x7fffba5feff3  libnetwork.dylib (856.60.1) <191E99F5-4723-3180-8013-02AF2F9AE4B8> /usr/lib/libnetwork.dylib
    0x7fffba5ff000 -     0x7fffba9d1047  libobjc.A.dylib (709.1) <70614861-0340-32E2-85ED-FE65759CDFFA> /usr/lib/libobjc.A.dylib
    0x7fffba9d4000 -     0x7fffba9d8fff  libpam.2.dylib (21.30.1) <71EB0D88-DE84-3C8D-A2C5-58AA282BC5BC> /usr/lib/libpam.2.dylib
    0x7fffba9d9000 -     0x7fffbaa0afff  libpcap.A.dylib (67.60.1) <F6BC6ED6-AEE4-3520-B248-0C342636E2B0> /usr/lib/libpcap.A.dylib
    0x7fffbaa27000 -     0x7fffbaa43ffb  libresolv.9.dylib (64) <A244AE4C-00B0-396C-98FF-97FE4DB3DA30> /usr/lib/libresolv.9.dylib
    0x7fffbaa93000 -     0x7fffbabe1ff7  libsqlite3.dylib (254.8) <1ECF7DF7-7A07-3B4B-A63B-F4EFF6BC7ACF> /usr/lib/libsqlite3.dylib
    0x7fffbacd6000 -     0x7fffbace3fff  libxar.1.dylib (357) <69547C64-E811-326F-BBED-490C6361BDCB> /usr/lib/libxar.1.dylib
    0x7fffbace4000 -     0x7fffbadd3fff  libxml2.2.dylib (30.17) <D4C3E467-37C6-34DE-8A1B-E7BFC29985E9> /usr/lib/libxml2.2.dylib
    0x7fffbadd4000 -     0x7fffbadfdfff  libxslt.1.dylib (15.9) <00735AD5-B62D-3E83-86AC-5533E4E2B102> /usr/lib/libxslt.1.dylib
    0x7fffbadfe000 -     0x7fffbae0fff3  libz.1.dylib (67) <46E3FFA2-4328-327A-8D34-A03E20BFFB8E> /usr/lib/libz.1.dylib
    0x7fffbae1e000 -     0x7fffbae22ff7  libcache.dylib (79) <093A4DAB-8385-3D47-A350-E20CB7CCF7BF> /usr/lib/system/libcache.dylib
    0x7fffbae23000 -     0x7fffbae2dfff  libcommonCrypto.dylib (60092.50.5) <8A64D1B0-C70E-385C-92F0-E669079FDA90> /usr/lib/system/libcommonCrypto.dylib
    0x7fffbae2e000 -     0x7fffbae35fff  libcompiler_rt.dylib (62) <55D47421-772A-32AB-B529-1A46C2F43B4D> /usr/lib/system/libcompiler_rt.dylib
    0x7fffbae36000 -     0x7fffbae3efff  libcopyfile.dylib (138) <819BEA3C-DF11-3E3D-A1A1-5A51C5BF1961> /usr/lib/system/libcopyfile.dylib
    0x7fffbae3f000 -     0x7fffbaec2fdf  libcorecrypto.dylib (442.50.19) <65D7165E-2E71-335D-A2D6-33F78E2DF0C1> /usr/lib/system/libcorecrypto.dylib
    0x7fffbaec3000 -     0x7fffbaef4fff  libdispatch.dylib (703.50.37) <6582BAD6-ED27-3B30-B620-90B1C5A4AE3C> /usr/lib/system/libdispatch.dylib
    0x7fffbaef5000 -     0x7fffbaefaffb  libdyld.dylib (433.5) <9B2AC56D-107C-3541-A127-9094A751F2C9> /usr/lib/system/libdyld.dylib
    0x7fffbaefb000 -     0x7fffbaefbffb  libkeymgr.dylib (28) <7AA011A9-DC21-3488-BF73-3B5B14D1FDD6> /usr/lib/system/libkeymgr.dylib
    0x7fffbaefc000 -     0x7fffbaf08fff  libkxld.dylib (3789.70.16) <BD02EF3F-6E09-3A64-AB21-553D5B1D2859> /usr/lib/system/libkxld.dylib
    0x7fffbaf09000 -     0x7fffbaf09fff  liblaunch.dylib (972.70.1) <B856ABD2-896E-3DE0-B2C8-146A6AF8E2A7> /usr/lib/system/liblaunch.dylib
    0x7fffbaf0a000 -     0x7fffbaf0fff3  libmacho.dylib (898) <17D5D855-F6C3-3B04-B680-E9BF02EF8AED> /usr/lib/system/libmacho.dylib
    0x7fffbaf10000 -     0x7fffbaf12ff3  libquarantine.dylib (85.50.1) <12448CC2-378E-35F3-BE33-9DC395A5B970> /usr/lib/system/libquarantine.dylib
    0x7fffbaf13000 -     0x7fffbaf14ffb  libremovefile.dylib (45) <38D4CB9C-10CD-30D3-8B7B-A515EC75FE85> /usr/lib/system/libremovefile.dylib
    0x7fffbaf15000 -     0x7fffbaf2dff7  libsystem_asl.dylib (349.50.5) <096E4228-3B7C-30A6-8B13-EC909A64499A> /usr/lib/system/libsystem_asl.dylib
    0x7fffbaf2e000 -     0x7fffbaf2eff7  libsystem_blocks.dylib (67) <10DC5404-73AB-35B3-A277-A8AFECB476EB> /usr/lib/system/libsystem_blocks.dylib
    0x7fffbaf2f000 -     0x7fffbafbcfef  libsystem_c.dylib (1158.50.2) <E5AE5244-7D0C-36AC-8BB6-C7AE7EA52A4B> /usr/lib/system/libsystem_c.dylib
    0x7fffbafbd000 -     0x7fffbafc0ffb  libsystem_configuration.dylib (888.60.2) <BECC01A2-CA8D-31E6-BCDF-D452965FA976> /usr/lib/system/libsystem_configuration.dylib
    0x7fffbafc1000 -     0x7fffbafc4fff  libsystem_coreservices.dylib (41.4) <7D26DE79-B424-3450-85E1-F7FAB32714AB> /usr/lib/system/libsystem_coreservices.dylib
    0x7fffbafc5000 -     0x7fffbafddfff  libsystem_coretls.dylib (121.50.4) <EC6FCF07-DCFB-3A03-9CC9-6DD3709974C6> /usr/lib/system/libsystem_coretls.dylib
    0x7fffbafde000 -     0x7fffbafe4fff  libsystem_dnssd.dylib (765.50.9) <CC960215-0B1B-3822-A13A-3DDE96FA796F> /usr/lib/system/libsystem_dnssd.dylib
    0x7fffbafe5000 -     0x7fffbb00eff7  libsystem_info.dylib (503.50.4) <611DB84C-BF70-3F92-8702-B9F28A900920> /usr/lib/system/libsystem_info.dylib
    0x7fffbb00f000 -     0x7fffbb031ff7  libsystem_kernel.dylib (3789.70.16) <34B1F16C-BC9C-3C5F-9045-0CAE91CB5914> /usr/lib/system/libsystem_kernel.dylib
    0x7fffbb032000 -     0x7fffbb079fe7  libsystem_m.dylib (3121.6) <86D499B5-BBDC-3D3B-8A4E-97AE8E6672A4> /usr/lib/system/libsystem_m.dylib
    0x7fffbb07a000 -     0x7fffbb098ff7  libsystem_malloc.dylib (116.50.8) <A3D15F17-99A6-3367-8C7E-4280E8619C95> /usr/lib/system/libsystem_malloc.dylib
    0x7fffbb099000 -     0x7fffbb0f2ffb  libsystem_network.dylib (856.60.1) <369D0221-56CA-3C3E-9EDE-94B41CAE77B7> /usr/lib/system/libsystem_network.dylib
    0x7fffbb0f3000 -     0x7fffbb0fcff3  libsystem_networkextension.dylib (563.60.2) <B021F2B3-8A75-3633-ABB0-FC012B8E9B0C> /usr/lib/system/libsystem_networkextension.dylib
    0x7fffbb0fd000 -     0x7fffbb106ff3  libsystem_notify.dylib (165.20.1) <B8160190-A069-3B3A-BDF6-2AA408221FAE> /usr/lib/system/libsystem_notify.dylib
    0x7fffbb107000 -     0x7fffbb10ffe7  libsystem_platform.dylib (126.50.8) <897462FD-B318-321B-A554-E61982630F7E> /usr/lib/system/libsystem_platform.dylib
    0x7fffbb110000 -     0x7fffbb11aff7  libsystem_pthread.dylib (218.60.3) <B8FB5E20-3295-39E2-B5EB-B464D1D4B104> /usr/lib/system/libsystem_pthread.dylib
    0x7fffbb11b000 -     0x7fffbb11eff7  libsystem_sandbox.dylib (592.70.1) <4B92EC49-ACD0-36AE-B07A-A2B8152EAF9D> /usr/lib/system/libsystem_sandbox.dylib
    0x7fffbb11f000 -     0x7fffbb120ff3  libsystem_secinit.dylib (24.50.4) <F78B847B-3565-3E4B-98A6-F7AD40392E2D> /usr/lib/system/libsystem_secinit.dylib
    0x7fffbb121000 -     0x7fffbb128ffb  libsystem_symptoms.dylib (532.50.47) <3390E07C-C1CE-348F-ADBD-2C5440B45EAA> /usr/lib/system/libsystem_symptoms.dylib
    0x7fffbb129000 -     0x7fffbb13cff7  libsystem_trace.dylib (518.70.1) <AC63A7FE-50D9-3A30-96E6-F6B7FF16E465> /usr/lib/system/libsystem_trace.dylib
    0x7fffbb13d000 -     0x7fffbb142ffb  libunwind.dylib (35.3) <3D50D8A8-C460-334D-A519-2DA841102C6B> /usr/lib/system/libunwind.dylib
    0x7fffbb143000 -     0x7fffbb16cff7  libxpc.dylib (972.70.1) <BF896DF0-D8E9-31A8-A4B3-01120BFEEE52> /usr/lib/system/libxpc.dylib
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 6262
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=249.8M resident=0K(0%) swapped_out_or_unallocated=249.8M(100%)
Writable regions: Total=131.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=131.6M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               256K        3
Activity Tracing                   256K        2
CG backing stores                 8540K        5
CG image                            84K        9
CoreAnimation                       84K        8
CoreUI image data                 2876K       14
CoreUI image file                  184K        5
Kernel Alloc Once                    8K        2
MALLOC                            92.4M       41
MALLOC guard page                   48K       10
Memory Tag 242                      12K        2
SQLite page cache                   64K        2
STACK GUARD                       56.0M        9
Stack                             11.6M        9
VM_ALLOCATE                        112K       15
__DATA                            20.6M      206
__GLSLBUILTINS                    2588K        2
__IMAGE                            528K        2
__LINKEDIT                       116.2M        8
__TEXT                           133.6M      206
__UNICODE                          556K        2
mapped file                       55.4M       14
shared memory                     16.4M       12
TOTAL                            517.9M      565
Model: MacBookPro12,1, BootROM MBP121.0167.B33, 2 processors, Intel Core i7, 3,1 GHz, 16 GB, SMC 2.28f7
Graphics: Intel Iris Graphics 6100, Intel Iris Graphics 6100, Built-In
Memory Module: BANK 0/DIMM0, 8 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445424533303445422D45474346202020
Memory Module: BANK 1/DIMM0, 8 GB, DDR3, 1867 MHz, 0x80CE, 0x4B3445424533303445422D45474346202020
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x133), Broadcom BCM43xx 1.0 (7.21.171.130.1a1)
Bluetooth: Version 5.0.5f1, 3 services, 17 devices, 1 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
Network Service: Thunderbolt Ethernet, Ethernet, en4
Network Service: Parallels Shared #0, Ethernet, vnic0
Network Service: Parallels Host-Only #1, Ethernet, vnic1
PCI Card: Apple 57762-A0, Ethernet Controller, Thunderbolt@195,0,0
Serial ATA Device: APPLE SSD SM0256G, 251 GB
USB Device: USB 3.0 Bus
USB Device: USB3.0 Hub
USB Device: USB3.0 dual display
USB Device: External USB 3.0
USB Device: Bluetooth USB Host Controller
USB Device: USB2.0 Hub
USB Device: Hub
USB Device: CP2102 USB to UART Bridge Controller
USB Device: USB Audio CODEC
USB Device: USB-Serial Controller D
USB Device: Vendor-Specific Device
USB Device: USB Storage
USB Device: Samsung S2 Portable
USB Device: Jabra UC VOICE 750a MS
Thunderbolt Bus: MacBook Pro, Apple Inc., 27.1
Thunderbolt Device: Thunderbolt to Gigabit Ethernet Adapter, Apple Inc., 3, 5.5
