Label error - SOLVED -
IS0FFD
Unread post by IS0FFD »
Hello!
I purchased the 3M x12 labels from 97mm x 42,3mm, 12 labels print correctly, from the start I noticed that on the "To radio" remains one of 8mm empty space, now I also need to write in the last row on QSL (Used Equipment), and printing is done in the label adjacent below.
question:
I can make the settings of the edges manually?
OS 10.10.5
HP Printer 1606dn record 0 to top, bottom, left, right.
Avery 4781 label paper
73 de Maurizio ISØFFD
Re: Label error
In RUMlog go to Menu-->Edit-->Page Setup
IS0FFD
Re: Label error
DL2RUM wrote:In RUMlog go to Menu-->Edit-->Page Setup
this is my screen shot, I can't select the profile created
:evil:
Re: Label error
"Format for:" set to "All Printer"
IS0FFD
Re: Label error
solved with this setting! :D :D
IS0FFD
Re: Label error
DL2RUM wrote:"Format for:" set to "All Printer"
Many thanks!!!!!
