[Solved] Voice Keyer on TS-590S No audio
Re: Voice Keyer on TS-590S No audio
Just tested again on a IC-7300, works perfect.
Crap.... I have no idea where to look next.....
Funny how this board doesn't have the ability to delete your own account.
Do you have tried Data mode? Volume is up? Is any other application using this audio codec?
Has nothing to do with it.DL2RUM wrote:Do you have tried Data mode?
Yes. But what I notice is that many times the default audio device for the Mac is set to the Codec. Is RumLog doing that?DL2RUM wrote:Volume is up?
Not that I know of. I usually try with no other applications running.DL2RUM wrote:Is any other application using this audio codec?
Ton.
When you start to playback over the radio, the saved output level will be set.
You can check the RUMlog function: just set the output device for radio to "Internal"
I think i found it. Whenever i play my audio file using Audio, Recording to File, Use for voice keyer i an only see audio on the left channel. The TS-590 only uses the right channel. So i converted the file to two channels and now things are working.DL2RUM wrote:When you start to playback over the radio, the saved output level will be set.
Thanks for your support (and patience).
Ton.
