Purple Screen - Exception
VE3DS
Unread post by VE3DS »
When I try to import adif to NG I get a purple screen exception as attached.
Yosemite 10.10.2
Dana VE3DS
VE3DS
Re: Purple Screen - Exception Error Messages
2015-02-19 6:34:27.567 PM RUMlogNG[497]: com.apple.message.domain: com.apple.crash_reporter.bear_trap
com.apple.message.summary: error while checking Apple Internalness
com.apple.message.details: Error Domain=NSCocoaErrorDomain Code=4099 "Couldn’t communicate with a helper application." (The connection to service named com.apple.CrashReporterSupportHelper was invalidated.) UserInfo=0x60000027d100 {NSDebugDescription=The connection to service named com.apple.CrashReporterSupportHelper was invalidated.}
SenderMachUUID:
and
Process: com.apple.appkit.xpc.openAndSavePanelService [1744]
Path: /System/Library/Frameworks/AppKit.framework/Versions/C/XPCServices/com.apple.appkit.xpc.openAndSavePanelService.xpc/Contents/MacOS/com.apple.appkit.xpc.openAndSavePanelService
Identifier: com.apple.appkit.xpc.openAndSavePanelService
Version: 1.0 (1)
Build Info: AppKit-1344072000000000~1
Code Type: X86-64 (Native)
Parent Process: ??? [1]
Responsible: RUMlogNG [1733]
User ID: 501
Date/Time: 2015-02-16 21:49:22.154 -0500
OS Version: Mac OS X 10.10.2 (14C109)
Report Version: 11
Anonymous UUID: D4DC2C4C-8162-F98C-E481-80ECEDA9D96C
Time Awake Since Boot: 16000 seconds
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x000007f9caac5450
VM Regions Near 0x7f9caac5450:
MALLOC_LARGE 00000001120f5000-00000001125ba000 [ 4884K] rw-/rwx SM=PRV
MALLOC_NANO 0000600000000000-0000600000800000 [ 8192K] rw-/rwx SM=PRV
Application Specific Information:
objc_msgSend() selector name: hasAmbiguousLayout
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 libobjc.A.dylib 0x00007fff8a59b0dd objc_msgSend + 29
1 com.apple.AppKit 0x00007fff90d07332 -[NSView viewWillDraw] + 1138
2 com.apple.AppKit 0x00007fff90d05f90 -[NSView _sendViewWillDrawInRect:clipRootView:] + 1417
3 com.apple.AppKit 0x00007fff90ce7b99 -[NSView displayIfNeeded] + 1216
4 com.apple.AppKit 0x00007fff90e11a17 -[NSNextStepFrame displayIfNeeded] + 39
5 com.apple.AppKit 0x00007fff90d051c5 -[NSWindow displayIfNeeded] + 232
6 com.apple.AppKit 0x00007fff90d42322 _handleWindowNeedsDisplayOrLayoutOrUpdateConstraints + 936
7 com.apple.AppKit 0x00007fff9130b0e1 __83-[NSWindow _postWindowNeedsDisplayOrLayoutOrUpdateConstraintsUnlessPostingDisabled]_block_invoke1531 + 46
8 com.apple.CoreFoundation 0x00007fff8f59cda7 __CFRUNLOOP_IS_CALLING_OUT_TO_AN_OBSERVER_CALLBACK_FUNCTION__ + 23
9 com.apple.CoreFoundation 0x00007fff8f59cd00 __CFRunLoopDoObservers + 368
10 com.apple.CoreFoundation 0x00007fff8f58ee08 __CFRunLoopRun + 872
11 com.apple.CoreFoundation 0x00007fff8f58e858 CFRunLoopRunSpecific + 296
12 com.apple.HIToolbox 0x00007fff938f6aef RunCurrentEventLoopInMode + 235
13 com.apple.HIToolbox 0x00007fff938f676e ReceiveNextEventCommon + 179
14 com.apple.HIToolbox 0x00007fff938f66ab _BlockUntilNextEventMatchingListInModeWithFilter + 71
When exactly does this happen? After selecting the file?
VE3DS
Hello Tom
Yes, open the log program, with empty log, then hit import ADIF...
select file...
Then it seems the process hangs or slows down, then purple exception screens...will try to do a screen print
with the text ... almost looks like some kind of field parsing of the ADIF table...
73 Dana
VE3DS
This is purple screen
Screen Shot 2015-02-19 at 8.24.16 PM.png (31.15 KiB) Viewed 10008 times
this is comment from right click on right side...
Very interesting. I have an idea what happened, but I don't know why. It seems you are the only one with this problem. It seems to me, the window in question is a standard OS-X open file requester. You was not able to select a file before the crash happened, right?
Please try the following:
  • Start RUMlogNG
  • Open the Terminal and enter as mentioned in the printout:
     defaults delete de.dl2rum.RUMlogNG NSConstraintBasedLayoutVisualizeMutuallyExclusiveConstraints
  • Go to the ADIF import
This flag will be set each time RUMlogNG starts. When this workaround works for you, I will remove this flag from the code. It is a trouble shooting aid for windows wit an incorrect layout. In this case, I have no control, since it is an OS-X window.
VE3DS
Hello Tom
Ok will try this.
I was able to select the .adif file to import, but then it appears to fail, as no file is imported ....
Dana
Osx 10.10.2
VE3DS
Tom, ran script, now purple screen gone.
Tried to import ADIF to log, did not work
Imported log from Rumlog and it came over ok, 1 DXCC missing, ZS3AK in old SW Africa back from 1980 on 6 m....
will try to patch DXCC for that one...all else ok.
But ADIF import not working, or maybe I didn't import the log properly??
73 Dana VE3DS
VE3DS
Hmm.... shows 120 now DXCC ... should be 121...
going to be hard to find 1 missing country, hi hi...
Need some tool to export DXCC list...
VE3DS
Ok Tom
I have DXCC correct now...somehow in the import of the old RUMLOG data file, it dropped LY2BAW from 2001 QSO...so manually added it.
Total is correct now.
Finding DXCC's is not easiest in RUMLOG.
VQLOG has a nice print out of Entity, Conf QSL, Call, Date, Time, Band...
by mode or all, by band... very simple to find
I used it to find the missing LY...
ALSO
Please, can you add 33 cm band 902- 928 in North America.
I am VHFer and VHF Contester, this is of course important to have ALL the correct VHF bands in North America, for general logging and CONTEST hihi
I see 1.25 cm is kind of hidden in the list also....222 - 225 Mhz
73 Dana VE3DS
