printing worked but not confirmed DXCC qsl cards
KD3NB
Unread post by KD3NB »
Is there an easy way to print qsl cards or generate an adif file from the results of the search in the logbook search window that lists the qso's worked but not confirmed for DXCC? Thanks.
Re: printing worked but not confirmed DXCC qsl cards
  • Open the "Search Window": Menu-->Window->Search
  • Select the "DXCCs" tab in the upper left corner
  • Select "Wkd but not ccd DXCCs" from the popup menu below
  • Select a band and or a mode to see also new band/mode QSOs
  • Push the "Run Query" button --> All wkd and not cfd DXCCs are listed in the right hand table
  • Push the "Show QSOs" button --> All wkd and not cfd QSOs from the DXCCs in the table are listed now in the QSO table
  • Go to Menu-->QSL-->Send again paper QSL
  • To print the cards: Go to Menu-->QSL-->Print paper QSL
To save the QSOs as ADIF file:
  • Select the "QSOs" tab in the upper left corner
  • Select "ADIF" from the popup menu on the right side
  • Push the "Save" button
KD3NB
Thanks Tom. Worked perfectly. - Ken
