Contest Definition Files, Contest Maker
Russian DX Contest
Here the files for the upcoming Russian DX Contest including the oblasts:
- Attachments
- Russian DX UA-side.plist
- (16.55 KiB) Downloaded 1169 times
- Russian DX dx-side.plist
- (16.64 KiB) Downloaded 1191 times
More contests
I added more contests. Please download the latest full package:
http://dl2rum.de/rumsoft/RUMPed.html
- UBA Spring Contest
- BARTG RTTY Contest
- NA Sprint Contest
- EA PSK/RTTY Contest
Wisconsin QSO Party
There is an issue for the WI-side. When you log a QSO outside W/VE RUMped complains the multiplier, just disregard and log it anyway. Multiplier and point scoring should be okay. I will correct this until the next WI QSO party.
- Attachments
- Wisconsin QSO Party dx-side.plist
- (15.67 KiB) Downloaded 1207 times
- Wisconsin QSO Party WI-side.plist
- (22.46 KiB) Downloaded 1141 times
New York QSO Party
As a member of the sponsoring club, I took it upon myself to build a contest form for the New York QSO Party. It is a few months away, but I decided to start now to make sure I have the bugs worked out.
Andrew, N3LZG
http://www.nyqp.org
http://www.rdxa.com
Andrew, N3LZG
http://www.nyqp.org
http://www.rdxa.com
- Attachments
- New_York_QSO_Party.plist.zip
- (3.32 KiB) Downloaded 1127 times
Find attached plugins for the 160m ARRL contest. It's not included yet in the downloadable archive.
- Attachments
- ARRL 160m W-side.plist
- (17.22 KiB) Downloaded 1237 times
- ARRL 160m dx-side.plist
- (17.21 KiB) Downloaded 1206 times
Here's a few contest definitions I made up over the last day or so; If someone could check them out and make sure they look sane, that would be great. I'm new to both the program, and contesting in general, so I don't know if I'm reading the rules right and/or setting up the contest properly. Some of the options confused me a bit, but I also admit to not reading the manual *completely* before diving in :>
Someone else recently uploaded a New York QSO Party file, but that was for NY stations; this one should be for the DX side if I did it right.
- Attachments
- New_York_QSO_Party (DX-side).plist
- (15.3 KiB) Downloaded 1123 times
- Iowa QSO Party.plist
- (18.85 KiB) Downloaded 1126 times
- Illinois QSO Party (dx-side).plist
- (19.37 KiB) Downloaded 1201 times
Here the files for the upcoming 10m ARRL contest:
- Attachments
- ARRL 10m NA-side.plist
- (20.28 KiB) Downloaded 1200 times
- ARRL 10m non NA-side.plist
- (20.63 KiB) Downloaded 1217 times
- N8NOE
- Location: Waterford, MI. USA [30 Miles, N.W. of Detroit]
- Contact:
Thanks Tom for all the Hard Work!..
Been Busy with the New Job, and just lost all my Time. Hope to get in the ARRL-10M Contest some, but have an Antenna to get up first.
New Icom IC-7700, ACOM 2000A Amp, Palstar HF-Auto Tune and more, just not time to sit and Run..
All this and Still using the AEA-PK-900
73 Jeff-N8NOE
73 Jeff-N8NOE
"Laissez les Contest Roulez!"
I just downloaded this file (my first that wasn't included in the initial RUMPed) and cannot figure out what to put for locator. Not sure why I am struggling. I have tried VA, FM19, W/VE, etc... all without success. HELP!DL2RUM wrote:Here the files for the upcoming 10m ARRL contest:
Thanks for any ideas, I am having a "moment",
Zach
N4ERZ AT arrl.net
RAC Winter contest file
Hello;
Brand new to RUMped, having been frustrated with my current logging program for contests.
I am trying to make a scoring file for the RAC Winter (which should also work for the sister RAC Canada Day) contest.
The rules are http://www.rac.ca/en/rac/programmes/con ... French.pdf
And my attempt to create a file is attached. I started with a contest that looked similar and hacked away.
Three issues spring to mind, and I'm not how to fix them
1) I don' t know how to have the multipliers work on each band. I clicked the "multipliers count on multiple bands", but no dice...
2) The contest is valid on 2M although I do not play there, and I don't know many that do.
3) Last is that there are certain stations that are higher points (i.e. the RAC sponsored stations). I didn't see a way to have specific callsigns be worth *more* than usual.
Comments and fixes appreciated.
Thanks for the closest thing to N1MM that I have seen on the Mac - wow!
Scott VA3NMI
Scott VA3NMI
- Attachments
- RACWINTER2.plist
- (9.6 KiB) Downloaded 1144 times
RACWINTER2.plist
