You have an error in your MySQL syntax; check the manual the corresponds to your MySQL server version for the right syntax to use near 'TYPE=MYISAM' at line 1Code: Select all
You have an error in your MySQL syntax; check the manual the corresponds to your MySQL server version for the right syntax to use near 'TYPE=MYISAM' at line 15.5.8 mysql on 10.5.8 OSXDL2RUM wrote:Which MySQL version do you use? On what a machine?
I reverted back to 5.0,DL2RUM wrote:I'm still using 5.1.26. Maybe there were some changes. I removed the MYISAM option during creating the tables, since it is the default type on a Mac.
Please try attached version.
http://dl2rum.de/rumsoft/RUMpedToTest.zip
