QRZ lookup, show path?
PG4I
Unread post by PG4I » Thu 3. Jan 2019, 16:26
Howdy folks, happy newyear!
I have started using RUMlog2Go on my ipad on january first. I have entered my QRZ.com credentials in the log setting, triple tapping the QSO looks up the call correctly in a new screen. There is a button called “show path” but I never see a correct line. Sometimes there is no line, sometimes there is one but it poins into the atlantic ocean west of africa (south of Togo actually). Is this a bug?
So far very happy with the logger, thanks!
Re: QRZ lookup, show path?
Unread post by DL2RUM » Thu 3. Jan 2019, 16:48
Do you have payed for the qrz.com logbook xml subscription?
PG4I
Unread post by PG4I » Thu 3. Jan 2019, 17:55
No sir, do I need to?
Unread post by DL2RUM » Thu 3. Jan 2019, 18:00
Yes Sir!
Or you could use HamQTH.com.
PG4I
Unread post by PG4I » Thu 3. Jan 2019, 18:12
Thanks for the tip Tom, will try it out.
Regards,
Joop
PG4I
Unread post by PG4I » Thu 3. Jan 2019, 18:36
Awwww, that is much better! Thanks!
