I finally figured out why I couldn't get RUMlog's Digi window to work in RTTY via cocoaModem. It's because I am using the Rig interface for TenTec Orion with my TenTec Eagle. The Oriion has a RTTY mode. The Eagle does not, so I use LSB for AFSK RTTY. I can get the Digi window to do RTTY if I disconnect the Eagle from rig control. This is not a big deal as I can use cocoaModem stand-alone and it still logs to RUMlog through the scripts.
73, Art W2NRA
