Tx with RUMlog and 7610
bassplayerjoe
Unread post by bassplayerjoe » Tue 29. Jan 2019, 18:30
A followup to my earlier question:
I am unable to trigger Tx in WSJT-X by, for example, double-clicking a CQ decode when my 7610 is being controlled by RUMlog. Instead, the frequency display shifts from (say, on 20M) from 14074 to 14073.5, the Tx light illuminates, but no signal is output. If I return to controlling the rig with WSJT-X, everything behaves normally.
I have tried multiple combinations of the RTS and PTT settings as described in the documentation, but without success. Have I missed a Tx command in the RUMlog documentation?
Would you have any suggestions?
thanks,
Joe/WB0CDY
Re: Tx with RUMlog and 7610
Unread post by DL2RUM » Tue 29. Jan 2019, 22:21
When the TX light is on and the frequency shifts, then the CAT and the PTT work as expected! When there is no signal out, you have to check your audio routing, your selected mode and your audio levels.
bassplayerjoe
Unread post by bassplayerjoe » Wed 30. Jan 2019, 04:04
Thanks Tom,
I'm still confused, as the audio routing, selected mode and audio levels levels are identical when I control the rig with either WSJT-X or RUMlog. The only difference appears to be the choice of control program. Are there any specific settings in the Tx1 menu that I should be checking, or has someone published a menu of settings that I can check against mine?
Joe/WB0CDY
Unread post by DL2RUM » Wed 30. Jan 2019, 10:34
You have to select the proper Data mode for WSJT-X.
Since we don't know your configuration and your station setup, it's hard to help.
bassplayerjoe
Unread post by bassplayerjoe » Wed 30. Jan 2019, 20:03
I got it and am quite excited! After going through your notes, documentation and tracing the signal again, I now have the correct settings for rig control through RUMlog and proper triggering of transmission through WSJT-X. Thanks for the suggestions, which ultimately led me to the resolution.
Also, a bigger thank you for all your help. I assume that maintenance of RUMlog is not your day job, and I really appreciate what you've put together. This is a terrific piece of software, and I look forward to further experimentation now that I have all the pieces talking to one another.
best regards and 73,
Joe/WB0CDY
