Page 1 of 2
RUMlogNG not talking to transceiver....
Posted: Tue 12. Jun 2018, 22:31
by DougY
I'm running RUMlogNG with my Icom 746Pro, and try as I might, I cannot seem to configure it correctly.
The application is not showing the frequency as I change it on my radio...any suggestions on proper configuration?
Re: RUMlogNG not talking to transceiver....
Posted: Tue 12. Jun 2018, 22:40
Show us your settings.
Explain your hardware setup.
Posted: Tue 12. Jun 2018, 23:08
by DougY
DL2RUM wrote:Show us your settings.
Icom 746Pro, CI-V Cable to an iMac Computer.
Manufacturer: Icom
Type: IC-746PRO
Serial Port: usbserial-A10734G0
Baud: 9600
Interface: Serial
For PTT use: TRX CAT
Posted: Tue 12. Jun 2018, 23:12
by DougY
DougY wrote:DL2RUM wrote:Show us your settings.
Manufacturer: Icom
Type: IC-746PRO
Baud: 9600
Interface: Serial
Icom Address: 0x66
Posted: Wed 13. Jun 2018, 08:13
Can you provide a screen shot of the trx setting pane please?
Posted: Wed 13. Jun 2018, 15:11
by DougY
DL2RUM wrote:Can you provide a screen shot of the trx setting pane please?
Posted: Wed 13. Jun 2018, 15:16
by DougY
Posted: Wed 13. Jun 2018, 15:20
by DougY
Posted: Wed 13. Jun 2018, 15:55
You have to enable the option “Use CAT”.
Why do you have selected a serial port in the microHAM settings? Do you use a MKII or DKII?
Posted: Wed 13. Jun 2018, 23:34
by DougY
DL2RUM wrote:You have to enable the option “Use CAT”.
OK, I put a checkmark on Use CAT, and I removed the serial port in the microHAM settings. Will see how it works now.
