CW and Phone keyer with MicroHam USB II
Posted: Tue 23. Sep 2008, 03:31
Hi Tom-
I'm still using the micoHAM USB Interface II with my IC 746pro here. I do have rig data appearing in RUMped the way it should...I can change band/mode from the computer and vice versa. I'd like to get the CW and phone keyers to work if I can. (They both work in MacLogger DX).
On the Preferences>>>Phone tab, I have selected an audio file that plays when I hit F1. But it does not trigger the PTT in the radio. If I go to the TRCVR tab and check the box DTR it does not work either. If I check the RTS box and save it, the rig goes into transmit and stays transmitting until I go back and uncheck the box. In your "New in RUMped 2.0" pdf file, I noticed that there is support for some microHAM devices, but the last paragraph says to refer to MH original windows software, which doesn't make sense to use on a Mac.
On the General tab, I tried selecting the microHAM port from the drop down menu (usbserial-U2PMQN1X), and checking the CW and Voice boxes, but when I hit save I get an error " can't open port for microham!"
I'm probably missing something, or maybe the USB II just isn't compatible.
Chris
KF7P
Chris
KF7P
