I tried to use LoTW Out this morning, and RUMlogNG returned the attached error message
Can't use tqsl:
The file couldn’t be opened because it isn’t in the correct format.
RUMlogNG Version 1.2.5 (56)
OS-X 10.10.5
tqsl v2.1.2 build (v2.1.2)
Trusted QSL Library v2.5
Configuration data v2.10
Any suggestions?
Don
W0DJC
LoTW error message
Re: LoTW error message
Do you have made changes to your tqsl application? Maybe an update?
This error means, RUMlogNG is not allowed to start the tqsl application due to a sandbox restriction. Go to the RUMlog preferences and reset your path to the tqsl app.
I did update my tqsl app, but not until I had the problem trying to use LoTW Out. I thought that perhaps I had to update to make it work.
I tried to reset my path to the tesl app, but the problem persists after doing so.
Don
Don
Today is the first day I have had the problem. Last time I used it was back in March of this year.
I reset "Select path to .tqsl folder" and it now works.
It isn't a new path, it has never changed, but for some reason, it now works.
Don
Don
