RUMlogNG will not save preferences.
k4zrj
Unread post by k4zrj »
Can't get it to save anything added under RUMlogNG>Preferences.
I add entries, click Close, but the next time I start RUMlogNG, nothing was saved. I'm presented a blank logging window which does not have focus, so I click on the logging window to gain focus, then I can open my log file, but no preferences are retained. The log file seems to be OK, but program preferences are gone.
Version 1.0.7.
73, Charles, K4ZRJ
Re: RUMlogNG will not save preferences.
I experienced a similar problem with another application. Please reboot your Mac and try again.
k4zrj
I rebooted the Mac and it now seems to save preferences, but, it still will not open the log file that was open when the app was last closed. Plus, after I manually open the log file, I have to change the "ALL QSOs" filter option to finally get the app to display log entries. Still presented with the same initial screen with the October 2014 filter selection.
How do you "reset" the filter (search) values. Don't see a "reset" button like RUMlog had.
73, Charles, K4ZRJ
Cmd W resets all the fields.
k4zrj
Console log from starting RUMlogNG:
2/28/15 18:32:53.164 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-metadata /Library/Preferences/com.apple.security-common.plist
2/28/15 18:32:53.000 kernel[0]: Sandbox: appleeventsd(57) deny file-read-metadata /Library
2/28/15 18:32:53.000 kernel[0]: Sandbox: appleeventsd(57) deny mach-lookup com.apple.ocspd
2/28/15 18:32:53.172 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-data /Library/Preferences/com.apple.security-common.plist
2/28/15 18:32:53.179 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-metadata /Library
2/28/15 18:32:53.185 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-metadata /Library
2/28/15 18:32:53.190 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-metadata /Library
2/28/15 18:32:53.195 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-metadata /Library
2/28/15 18:32:53.199 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-metadata /Library
2/28/15 18:32:53.205 sandboxd[227]: ([57]) appleeventsd(57) deny file-read-metadata /Library
2/28/15 18:32:53.260 RUMlogNG[552]: Invalid color System, labelColor (warning given only once)
2/28/15 18:32:53.530 RUMlogNG[552]: -[NSTableColumn setTitle:]: unrecognized selector sent to instance 0x600000096850
2/28/15 18:32:53.673 com.apple.geod[340]: Peer de.dl2rum.RUMlogNG asked to load a tile, but it lacks the correct entitlement.
2/28/15 18:32:53.674 RUMlogNG[552]: Your Application has attempted to access the Map Kit API. You cannot access this API without an entitlement. You may receive an entitlement from the Mac Developer Program for use by you only with your Mac App Store Apps. For more information about Apple's Mac Developer Program, please visit developer.apple.com.
2/28/15 18:32:53.674 com.apple.geod[340]: Peer de.dl2rum.RUMlogNG asked to load a tile, but it lacks the correct entitlement.
2/28/15 18:32:54.574 com.apple.geod[340]: Peer de.dl2rum.RUMlogNG asked to load a tile, but it lacks the correct entitlement.
Console log from manually opening existing log file:
2/28/15 18:33:37.524 com.apple.appkit.xpc.openAndSavePanelService[555]: assertion failed: 13F34: liblaunch.dylib + 25164 [A40A0C7B-3216-39B4-8AE0-B5D3BAF1DA8A]: 0x25
2/28/15 18:33:37.669 com.apple.appkit.xpc.openAndSavePanelService[555]: Bogus event received by listener connection:
<error: 0x7fff7784eb50> { count = 1, contents =
"XPCErrorDescription" => <string: 0x7fff7784ee60> { length = 18, contents = "Connection invalid" }
2/28/15 18:33:37.671 librariand[220]: client process 552 does not have a valid com.apple.developer.ubiquity-container-identifiers entitlement
2/28/15 18:33:37.671 librariand[220]: error in handle_container_path_request: LibrarianErrorDomain/9/The client process does not have a valid com.apple.developer.ubiquity-container-identifiers entitlement
2/28/15 18:33:37.994 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:37.995 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:37.995 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:37.995 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.013 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.013 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.013 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.013 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.029 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.030 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.030 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.030 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.046 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.046 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.046 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.047 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.063 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.063 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.063 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.063 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.084 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.086 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.086 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.086 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.096 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.096 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.097 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.097 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.112 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.112 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.112 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.112 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.129 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.129 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.129 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.129 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.146 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.146 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.147 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.147 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.162 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.163 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.163 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.163 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.180 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.180 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.180 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.180 WindowServer[144]: CGXSetWindowListAlpha: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.195 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:38.196 com.apple.appkit.xpc.openAndSavePanelService[555]: CGSSetWindowTransformAtPlacement: Failed
2/28/15 18:33:38.196 com.apple.appkit.xpc.openAndSavePanelService[555]: ERROR: CGSSetWindowTransformAtPlacement() returned 1001
2/28/15 18:33:38.196 WindowServer[144]: CGXSetWindowTransform: Operation on a window 0x16c requiring rights kCGSWindowRightPresenter by caller com.apple.appkit.xpc.openAndSav
2/28/15 18:33:42.000 kernel[0]: Sandbox: RUMlogNG(552) deny file-read-data /Users/charlesbjohnson/Documents/K4ZRJ.rlog
2/28/15 18:33:42.367 RUMlogNG[552]: Error saving Logfile URL: The file “K4ZRJ.rlog” couldn’t be opened.
2/28/15 18:33:42.765 RUMlogNG[552]: view service marshal for <NSRemoteView: 0x7fd1a344e710> failed to forget accessibility connection due to Error Domain=NSCocoaErrorDomain Code=4099 "Couldn’t communicate with a helper application." (The connection was invalidated from this process.) UserInfo=0x608000461500 {NSDebugDescription=The connection was invalidated from this process.}
timestamp: 23:33:42.764 Saturday 28 February 2015
process/thread/queue: RUMlogNG (552) / 0x10817b000 / com.apple.NSXPCConnection.user.endpoint
code: line 2972 of /SourceCache/ViewBridge/ViewBridge-46.2/NSRemoteView.m in __57-[NSRemoteView viewServiceMarshalProxy:withErrorHandler:]_block_invoke
domain: communications-failure
2/28/15 18:35:47.169 syncdefaultsd[558]: *** -[IADomainCache init]: IA domains cache couldn't be read.
2/28/15 18:35:47.170 syncdefaultsd[558]: -[IAPluginManager allAListPlugins] [546] -- *** warning: we're on the slow path.
End of console log results.
This is repeatable and happens with each open attempt.
Running OSX 10.9.5.
73, Charles, K4ZRJ
k4zrj
Cmd W does not clear the year, leaves it as 2014. But, after the log is opened, it does clear the year to "All".
73, Charles, K4ZRJ
Anybody else with this problem?
Charles, please delete the whole RUMlogNG (sandboxed) data folder in your Home: ~/Library/Containers/de.dl2rum.RUMlogNG. Deleting the app itself and reinstalling could be an option as well.
But before you start RUMlogNG again, reboot your Mac!
ddanecki
Unread post by ddanecki »
I would start with fixing permissions.
de SQ2KLU
Daniel
k4zrj
Did as you requested. Started by verifying/repairing permissions. Deleted app, container folder, preferences cache, everything related to RUMlogNG, and started over from scratch. Rebooted Mac. Imported new log from RUMlog classic, etc. Results same.
It will save preferences, but will not open existing or last used log file in Documents. The app opens with blank logging window which I posted earlier. I can send console log via email if you like, but is essentially the same as I posted in this forum.
The issue has something to do with sandboxing. My own apps I write in Xcode that open files don't seem to have this issue, but I'm on 10.9.5 and Xcode 6.1.1 with 10.9 or 10.10 SDK. I will try loading RUMlogNG on another machine that is not also my development machine, but it will have no access to the K3 or the keyer.
73, Charles, K4ZRJ
k4zrj
I loaded RUMlogNG on another Mac running 10.9.5 and observed the same behavior.
It will save preferences, but can't save the URL to the log file because of a sandboxing violation.
This violation occurs at the time I manually open the log, when the app tries to save the URL so it can be reopened.
73, Charles, K4ZRJ
